2 hours ago, Amcguy1970 said:
Go ride in a new Full Size SUV from GM with adaptive suspension and air ride, you will probably think otherwise. They rode nice back in the day but were a little floaty over larger bumps which off set the nicer ride on the smaller stuff (don't forget cars back then creaked and rattled over bumps). Our 2021 Yukon Denali is amazing at how well it rides. We have had all the GM flavors over the years including a 1975 Pontiac Grandville (talk about a massive boat with a 455) to Bonnevilles and Le Sabres/Park Avenues until switching to vans/suvs and trucks the last few decades and this new SUV rides incredible compared to anything else.
I would not be surprised if on the next gen the trucks adapted a IRS from the SUV's for the high end versions or the half tons as one of the engineers pointed out it was tough enough for truck stuff. With all these suburban dads buying the box checker trucks not to tow and haul but just drive to work and complain about the ride, well something like an air ride IRS with adaptive suspension will fix those complaints (until they start complaining about not having massaging seats or some other luxury car feature).
Tyler
I seriously doubt the ride is as nice as that old tahoe….or buick roadmaster, or a host of other 90’s boats.
I mean it’s pretty damn easy to design a suspension to be good at one single thing and suck at everything else. Also, tahoe had air suspension too….courtesy of the 5” smaller wheels than your denali.
I suppose I can’t really be sure without driving a new denali, but I’d seriously doubt it.
I’m not knocking your denali, it’s better than an old tahoe in like 999/1000 categories.
me saying the tahoe rides better than your denali is kinda like saying a 25 year old civic with cement poured in the water jackets and a 350shot of nitrous can beat a lambo in a rolling drag race. While technically true it’s not really relevant.
Edited by truckguy82
I just noticed oil leaking from one of my 5160s. Less than 2 years old and only about 25k miles on them. Unfortunately, I think they only have a 90 day warranty.
I just got off the phone with Bilstein and found out the 5160s have a 2 year warranty. Unfortunately, I'm just over that from the time of purchase but they haven't been installed for 2 years. I'm hoping to hear from the dealer to see if they can help before pulling the trigger on a pair of 5100s that have a lifetime warranty.
What a disappointment. I ended up buying a pair of 5100s to replace these, hopefully they last longer.
Looking at replacing my rear shocks and going back and forth between the 4600s and 5100s.
The 5100s seem more popular but several post on here describing a trampoline feeling with them. I do mostly highway driving with very little towing. Any advice or suggestions?
Not looking to ever lift the front or rear. I live in the south so not much issue with salt. Currently have the Z71 pink ranchos
Edited by Hogtiming
As I posted on your other post regarding this
"I'd go with the Bilstein 5100s.
Before I had them installed, on my lift, the stock shocks would bounce the truck over small speed bumps.
With them, it's been much, much better as I can over speed bumps with very little jounce and I watch trucks behind me jouncing as I used to.
That said, as @Grumpy Bear mentioned, there are many choices at many different price points. "
Edited by MikeBMW
On 6/6/2021 at 9:07 AM, summitcounty99 said:
Hello,
Anyone think the Bilstein 6112 series shock would be to much for just a simple replacement over the original Rancho shocks? I do not plan on lifting the truck; just asking and researching what other people have done and are happy with.
Thanks,
Rob
I had factory ranchos and was always happy with the ride.  Hit 100k and needed new tires so figured I'd get new shocks too since I'd heard that was about their lifetime and I could see the rears were rusted badly.  I've had 6112s (set on stock height) and 5100 rears for over a year now and am still super happy with them.  Them and the Blackbear tune are the best money I've ever spent on mods.  Roads around here are awful, and the 6112s eat up potholes and bumps like it's nothing.  I didn't measure before/after but I know for sure the front shocks lifted the front end of the truck after install, and it settled down a lot but fairly certain it's still higher than stock but a negligible difference.  I'd recommend them to anyone.  Can't speak for their longevity obviously.
I put 5100 shocks on my 2016 at 800 miles. It now has 4k miles. I have a metal clang sound on drivers side and deep thunk sound on drivers side when I turn. Is this normal for 5100 billsteins?
59 minutes ago, stevejones said:
Not normal.  Best to get the front end in the air, then manipulate the control arms with a floor jack & see what's moving that shouldn't be.
It doesn't happen every turn. Im sure i won't be able to replicate it in the air. I cant make it do it when I want when driving.  The thunk sounds like my 06 Silverado that had the uca bushing pop out and in
Take your truck in to a repair shop if you do not think you can find the source. No need in risking it falling apart on you while driving.
If you or whoever did your install did not use the factory Top Nut on the shock this could be where you're at noises coming from. The ones supplied by Bilstein do not have the built-in washer flare that the factory nuts do. Search this thread and you will see it mentioned.
Can it be identified with out removing anything?
    • Blazer is all put back together. Another hard-won battle. The 4.3 is not easy to work on in such an archaic and narrow chassis originally designed for an inline 4.   My baffle issue is solved. I returned to the OG junkyard but was ready for a fight. The Blazer I had picked from was stacked on another vehicle so I had no idea how the heck I was going to get myself to working height to pull the front end apart. I had seen an S10 pickup on the ground so I was hoping the part would be the same, AND, I couldn't remember if the S10 still had a front end or not. But I didn't need to worry because it turned out to be my lucky day. The yard had just taken in a '98 Blazer, sitting right up front, on the ground, with room to work around it, and the front end hadn't been hit. The baffle and all the clips were factory perfect. I also scored another good handful of odds/ends and the whole shebang only cost me $20.   Got everything back together and it fired right off, sounds good, runs good. I've got a little coolant drip from a lower water pump bolt (D'OH!!). I did the right thing and snugged it down a little bit, and of course that didn't fix it. Yet again, I will have to soak everything in coolant to drain it down to the water pump, remove the bolt, and attempt to re-seal it. Nothing is easy on this truck. Nothing. But now all the radiator plastics are correct, snug, and fully functional. No more rubbing on the cooling fan. It runs, drives (took it for a 30 mile drive last night), no Check Engine lights, EGR is working, no vacuum leaks. We're getting closer...   The replacement wiper motor arrived yesterday. The tailgate was already disassembled and waiting, so I threw that in. It works! Sort of. Two new issues on the list. While the motor is strong enough and the gears aren't stripped, the wiper is hanging up on the bottom of the rear glass. This is the old style where the lower half folds down like a truck tailgate, and the glass swings up, and they meet in the middle when closed. The glass isn't sitting flush with the tailgate, now that I look at it. No rubber bumpers that I can see for adjusting, so I'll have to look at the hinge adjustment to see if I can correct it. Also, the washer/squirter just dumps fluid underneath the truck. The lines actually run inside on the floor so I'm guessing the tailgate is soaked at the rear trim and the line is disconnected. There's also a drain there....probably for this reason.   The leaky water pump bolt was really disappointing. JUST STOP LEAKING...OMG!!   Replacing the window motor and a rear door speaker are still to do, and then everything will work. I want this to feel like a "good" vehicle worthy of dropping $600 for new tires before I do. That means no leaking first. I hurt, and I'm kind of cranky, so I'll probably take a day of rest and do the water pump again tomorrow.
    • Just saw on Jay Leno the new Scout. That’s the way it should be done.
    • EV's have their nuances too. Best to operate the current type of lithium batteries between 20-80% charge. No real need to charge until you hit around 20%. Occasionally charge to 100% when needed. Longer term storage, battery should be 50-60%. At least those are the guidelines for our iX. We've been exceptionally good to the battery in that car...easy to do when you can charge at home like we can.   EV's lack so many of the rituals and so much of the visceral feeling ICE vehicles provide, which is why I think they're hard to accept for a lot of gearheads. They're fun in different ways, though.
    • We have got a lot of rain lately, we needed it. Storms/lightning took out a floor fan. Dirt roads badly rutted from run off.   Power here is sketchy, whole house surge protector in the service panel and all electronics plugged into surge protectors. My biggest concern is my stereo, I've been an audio nut for years. $25 k in equipment. Stereo is on it's own special surge protector.
    • Happy Birthday!  I also turned 72 this year.  In some groups I consider myself to be a young senior and in others I realize I have serious years behind me!  In June I spent a week in the hospital due to a blood clot following knee replacement surgery.  The hospital Doctor assigned to my care specialized in Geriatric medicine!  He is a great Doctor but the fact I required this type of specialized care  made me feel old!  Aging comes with new challenges but I sure appreciate getting older!  It most definitely beats the alternative!!
