Over and Jarod from Gen5 just completed a harness for my 2016 Sierra to keep the C shape LED DRL's on full power. They are available for the SLE with the HID's and the SLT's as well. They are plug and play, no adding diodes are altering the factory wiring harness or BCM. They are $50 for the set.
Sent from my LG-V495 tablet using Tapatalk
what website is this? thanks
  • 1 year later...
Hey guys! New to the forum and a little late on the thread! I have done the diode swap, looks awesome love it. Only problem, I have switched to led headlights and now when in auto for some reason my lights are always on no matter what, and my passenger one will not come on unless I have the auto disabled and just turned to the right and on.  Any help?? It’s very  annoying but I like the drls always on!  Would t tapping help solve the problem??
I usually turn my fogs on, and that makes both top and bottom DRL's turn on, and they are brighter.
Late to this post myself so cannot see any of the pictures posted.
  • 5 weeks later...
On 9/20/2016 at 3:57 PM, FiveOH said:
Can someone pleaseeee take new pics of where the diodes go? For some reason the original pics from the 1st post are not showing up.
This^  I would like to do this as well, but the initial post's pics are not showing up.
Any way the new Chevy LEDs can run bright at night?
I'd like both my drl and turn signals to run bright at night. Actually.. I really want just much brighter LED's to start with. Then the dimmed function would be useful :)
Sent from my XT1585 using Tapatalk
  • 4 weeks later...
Same!
  • 3 weeks later...
  • 1 year later...
after someone bumped and cracked my 2015 SLT 1500 passenger headlamp, it got some water in it and led quit staying on at start
i got a brand new oem headlamp W oem led for SLT and the strips light up but then it goes out again - leaving only my driver side LED working properly.
does this make any sense to you guys? any clue where i should look? BCM ? it flickers the instant truck starts but then goes out
PLEASE HELP - USA FACTORY truck. not export or after market
  • 3 years later...
On 12/1/2023 at 4:48 PM, Huxley Wolfkin said:
Photos do not work anymore
The diode that is in just the brown plug is fogs with highs. The diode that goes from the brown to the pink 😉 is cargo lights in reverse.
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
