Replacing my aftermarket stereo with a new aftermarket
Hey all,
I purchased my truck a year and a half ago (second owner), and it had a Sony CD player. Last night, it crapped out while truck was running. I checked fuses, all was fine! so i figured the Sony just died. I just bought a replacement... a Pioneer, so I re-wired the new harness (thank god for colored wires!) and i turned my truck on, and still nothing out of the new unit.
am i missing steps here? I drive a ton, if i don't have radio, i'm going to lose my mind!!
2005 GMC Sierra WT Reg. Cab Short Bed 4x4
2005 GMC Envoy SLT 4x4
2004 Chevrolet Suburban LT 4x4
How about the ground? I assume you checked all the connections , but that ground can be tricky sometimes. Do you have a tester, you can see if you are getting your 12 volts at the wire harness? Does the unit power on and no sound or just nothing at all? Also, when I installed my aftermarket pioneer (2006 Sierra), i had to run a power wire from the head unit all the way to the fuse box. The wiring harness I bought came with it but it was separate from the wiring harness adapter. Check that power wire as well.
Hey Thanks for writing.
I will try and get my hands on a tester.. and yes, I have power going to the fuse box, most everything was already set for me because the radio that was in the truck when i bought it was an aftermarket. I am getting zero power to the unit!
