Always been a fan of the 4.3 since we've had them in S-10 trucks and Blazers (I know the motors aren't similar but still). Now I just want to see a re-envisiominf of the Big-Block V6's from the old GMC trucks. Maybe turbo'd as a base model 3/4 ton motor....
I have 47,000 on my 2014. I am happy with it, and as a bonus I am getting a 18.9 average mpg since I bought it. Prior to that, I had a very fun to drive 2003 SS, but it couldn't pass a gas station without gulping 50 bucks worth.
I own a 2014 with 22k miles. Honestly couldn't be happier. I had a 2013 prior to this with the v8 and I really cant tell much of a difference. I towed a uhaul (6x12) loaded up to the max from Wisconsin to New York and other than averaging 13-14 mpg, it handled the weight really well and had power to pass when needed. I went for the v6 because i rarely tow, and mainly like a truck because I could throw whatever I want in the back and I sit up above traffic. Plus I feel more safe. Didnt ever feel the need to have the v8 plus I got an amazing deal on my truck.
  • 4 weeks later...
I drive a 2014 DC with the 4.3 and Z71 Package. Absolutely love the truck. I modified the Airriad MIT for the 5.3 to fit the 4.3 engine. Currently planning on doing a black bear tune as well. I don't really tow anything, but i have had 1200 lbs of Concrete in the back a few months back, and truck drove like there was nothing there. I would recommend this engine to anyone.
Just curious how much modification was required for the MIT to fit and wether it made a difference or not.
Not much modification. Just need a 4 inch to 3 inch coupler for the throttle body and a half inch PVC plug. Hard to say how much of a difference it made. I feel like it did, but others on here would argue that it won't make a difference
  • 1 month later...
Other than the trans fluid temp running higher than I'm comfortable with, my 2015 4.3L is doing fine. Little over 3000 miles. I'm going to add a Tru Cool Mini Max trans cooler to it very soon & be done with the high fluid temps.
How did that TruCool work for you? Mine still hasn't jumped over 195F, but to be honest I'm a little sketched out by such a high reading on the highway.
I used to have the 4.3 ECO TEC, with 13k miles on my new 5.3 ECO TEC, I'd pay the $800 all day long to get the bigger motor. The 4.3 does the job but, it's nice to have that little extra in the V8. FWIW I had the 4.3 truck for about 30k miles and only a few times did I want more power, mostly on the highway, both trucks are 4x4 3.42 rear end double cabs. If you find a screaming deal on 4.3 don't hesitate they're good motors and I would buy a truck with one again IF it was about 2k less than a comparable 5.3L truck but, new, your talking less than 1000. Also I get the same MPG with this truck as I did the V6. 19 mpg without a trailer hooked up.
Installed it in Dec, but it didn't do much because of the Thermal Bypass Valve they have used since 2014. Install was fairly easy and I was real pleased with the way it turned out. I modified the valve (easy & free), and it really cooled it down. I can run the interstate in 95 degree SC weather at 145 degrees, or sit in heavy traffic at 175. I used the Tru Cool Mini Max 20k btu cooler. Well made. Torque converter and pump went out at 10k miles, so after dealing with that ordeal I feel better about the tranny running cooler. Cooler%202_zpsu08mwo4s.jpg
I have nearly 80000 kms on my 4.3 and so far my only complaint was towing a 4000 lbs camper with some stuff in the back of the truck. The issue was not being able to keep it in 6th gear so I had to run at 105 km/h @ 2800 rpm in 5th. Would like to know how the 5.3 would fare with that extra HP. Other than its been good.
I've driven one for 300 miles (double cab 4x4) so no ownership experience...but I do have a relevant question for you 4.3 owners. Anyone run the Range AFM delete on theirs? Interested to see some mileage differences between leaving it active and disabled.
5.3 would run in 5th with tow/haul on with that load.
  • 3 weeks later...
Has anyone done anything with the exhaust? I know most 5.3 owners just say to get a 5.3 but I'd like a little more throat when I hit it on the highway. Thx
I wanna know how everyone is getting 20+ mpg with their trucks. I have the 4.3 and the closest I've ever gotten to that is 18 when babying it. Normally I get around 15-16 highway.
So there is a big difference between what the computer tells you and what your actual mpg is. I was averaging around 20-22 with a max of 25 b4 my lift and tires but when I plugged the numbers into a mpg app it was more like 18. After my lift and tires I'm getting around 14-16.
Edited by NYSierra4
Yep, that's spot-on for me with my 4.3L. I think a lot of people who brag about high MPG are being a little dishonest with themselves and maybe not telling the whole story. When I calculate my MPG by hand, I usually get around 18 if I've been driving economically, and I've seen as low as 14-15 if I've been driving REALLY aggressively (I live in Socal, our freeways are a free-for-all deathmatch).
Yeah same here, the computer is waaay off on mine. And I'm running stock tires with no lift. Computer is off by as much as 3-4 mpg sometimes.
It boils down to how you drive and what type of truck you drive. Heavier tires and a level will decrease you mileage quite a bit when you have a v6. What did you average when the truck was stock?
This is what I've averaged so far with mine. 70% highway driving and 30% stop and go city driving. Also mixed with some spirited driving (Single cab, 2WD, 3.23s, bone stock)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
