How do you get to the tire jack?
Its behind the rear seats, but does the right side passenger seat top fold out away from the bed once you flip the bottom of the seat toward the bed? Do you just wedge your hand in there to get the jack out? I don't seem to be able to find any release for the seat? Ack.
If you're asking how to remove it, you also need to loosen it. It uses it own pressure to hold itself in place in its bracket
Owners manual was not real helpful in description beyond location. Info realize you have to spin the jack down bit to remove.
OM instructions:
For regular cab models, the equipment you will need is behind the passenger seat. For double and crew cab models, the equipment is on the shelf behind the passenger side second row seat.
1. Turn the knob on the jack counterclockwise to lower the jack head to release the jack from its holder.
2. Turn the wing nut counterclockwise to remove the wheel blocks and the wheel block retainer.
3. Turn the wing nut used to retain the storage bag and tools counterclockwise to remove it.
How did it work when you got it out?
Haven't had to use one since back in the days when the jack lifted on the bumper.
It's not hard to remove. Fold the bottom of the back seat up. Turn the wheel on the jack to lower it a bit and loosen it from its bracket. I used mine to lift the truck to remove the rear wheels to install splash guards. It wasn't the fastest jack but it was easier than moving my camper to get to my floor jack in the garage. It would be ok for changing a flat tire.
The instructions for removing the jack on U Haul rental trucks are easiest of all: there is no jack. And no spare wheel.
I get how to get the jack out, I guess I'm stumped as to why the rear of the seat does not fold down flat to access the area behind the rear seat so I could stash more stuff back there. You flip the bottom seat up and then have to spin the jack from there.
Because it doesn't. That's why. I don't think GM trucks rear seats have folded down ever. the bottom cushion always has folded up.
Actually, the rear seatbacks on my '06 crew cab fold down after the bottom cushions are flipped forward vertically. This way I can make relatively flat loading platform for luggage, etc. back there. Have they changed this?
You know I was still thinking in terms of extended cabs. Thats my bad. Im not sure about the crew cabs now that I think about it.
Yes, the rear seats on my 2005 Sierra fold down and make a "bed" platform area .......
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
