Message added by Zane,
Hey everyone, we noticed this question comes up a lot, so we finally put together one master cheat sheet. It covers the exact oil capacity, filter numbers, and drain plug torques for every GM truck and SUV from 2016 through 2026. Bookmark the full guide here so you never have to guess again: https://www.gm-trucks.com/gm-engine-oil-capacity-guide/
On my way to the Autozone and cannot find my manual on how many quarts to buy for my 2016 Silverado 5.3 V8.
Is it 8 or 8.5 quarts? 5w20 correct?
8, 0w20.
Sent from my SM-G930V using Tapatalk
What brand oil comes in these from the factory?
Fairly certain ACDelco brand labeled oil containers is ExxonMobil.
Doesn't the 2016 come with two Free oil change ?? my 2015 came with 4 Free oil change.
As part of the agreement, ExxonMobil will also market General Motors’ new semi-synthetic engine oil, ACDelco dexos1 5W30, to be launched later this year in the U.S. and Canada.
Just changed my oil yesterday. Poured an entire 5 quart container of Mobil 1 0W-20 plus 3 quarts of a second jug. Double checked dipstick level the next morning and it was right at the top of the cross hatch.
Originally it was 8.5 quarts. But For whatever reason GM changed the spec to 8 quarts.
Makes it easier to fill!
  • 3 years later...
REVIVING AN OLD TOPIC..
what's interesting is I have a 2015 5.3V8 and I have always had the dealer do the LOF.  They have put in 8 quarts.  Well, I went to another local dealer the other day and they said they put in 9 quarts.  The service tech says 'well, some take 8 and some take 9... its weird sometimes with these trucks'.
anyone weigh in on this? I feel stupid even typing this question but I have NEVER heard of such a thing.
Edited by Aaron1085
it doesn't look like it makes a difference whether you have a 'flex fuel' 5.3 or not, its still 8 quarts.
The dealership that states it takes 9 qts is a dealership to stay away from.  Everything is electronic.  Not sure how they can get the capacity wrong other than just not paying attention.
8qt as stated above.  That is why I like the fact that AMSOIL has it in gallons. Just pour in two gallons and you are good to go and no messing with qts or partial 5qt containers.
  • Zane locked this topic
This topic is now closed to further replies.
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
