Charge trailer batteries with alternators
austingta
I have dual alternators which are advertised to provide 380 Amps, and would like to use some of that to charge the batteries I plan to have in my travel trailer. I cant imagine I can get much current through the 12VDC+ pin in the trailer connector. What is the best way to access all this charging ability? Do I need to pull the power off my truck batteries and let the alternators recharge them, or is there a more direct way?
TIA
Your truck should be charging the batteries automatically. Mine always has as far as I know. The brain in the trailer should recognize when the truck is hooked up and let the charge go to the batteries in the trailer. Somehow it knows not to drain the truck battery when just sitting though. Unless all the batteries get drained maybe? I have never left it hooked up for very long.
The issue is not the amps you have but the length of wire and power loss from the truck to the trailer. It won't be enough to charge them much if at all. The best thing is a DC-input battery charger. It will give the trailer batteries the full charge. something like this http://www.powerstream.com/DCC.htm
Or run a heavier wire from the truck batteries to the rear plug...it's something like 10ga now, something nearer to 6 or 4ga would carry enough to charge batteries on the move.
Doesn't matter what you put to the trailer for power, the built-in charger in the trailer is a trickle charger and only charges so fast. Plugged into the truck or a 110VAC plug makes no difference.
So you understand, vehicles don't run off of the altinator, they run off of the battery, and the altinator tops up the battery. The addition of a second altinator allows you to add significantly more accessories and keep the battery topped up.
Sent from my Z30 using Tapatalk
Built in charger on trailers only comes into play when plugged into 110.
When plugged into a vehicle, then the trailer battery gets charged off of the vehicle battery.
And yes, vehicles do run off the alternator, batteries are used to start and to be a load balancer. You ever drive a vehicle with a bad alternator? They don't run vary long.
The alternator isn't meant to be a charger, but rather a maintainer. As long as you are not running the batteries down requiring a lot of demand on the alternator, I don't see an issue.
In the old days, I know that alternators ran accessories and charged the batteries. You could start the car, disconnect the battery and the car would still run just fine. That was a way we would test the alternator or voltage regulator in the driveway.
I also know those days are over, and the battery is an integral part of the vehicle electrical system.
My idea was that I might be able to install a battery array in my RV to avoid the necessity and operating expense of buying a generator. I would like to be able to run the AC while boondocking.
Since I have 380 A @ 12VDC of charging capacity, it should be possible to run a set of batteries for a long while and start the truck and recharge them.
Maybe I should just invest in some big battery cables, run it to the trailer, and start the truck (maybe even activate the fast idle switch) and run it for a couple of hours to recharge the batteries?
BTW It seems the LML uses .5 GPH at idle which is significantly less that a generator even just for fuel. .
I've seen heavy cables run from the front of the truck, for powering a dump trailer. With what the cables would cost to effectively put out power, it may well be cheaper and easier to get a generator.
Sent from my SM-G920V using Tapatalk
My 2011 has a 30 amp circuit to the trailer connector (after I hooked it up). I think this would charge the trailer batteries in most cases on a long drive. Your trailer connection should have an isolator so as not to deplete the truck battery. I would definitely use a 120VAC charger when available. That said I don't use a trailer with batteries so maybe I missed something here.
If you try to run the AC ( which is either 13k BTU or 15k BTU ) off of the batteries, you wont be able to do so for very long, if any. Which would make the added batteries and electrical connections rather worthless.
IMHO, if I were going to be boon docking, for any length of time or on a regular basis. I would go with solar to help keep your batteries charged.
This reminded me that I do this with a big Warn winch I have welded to a ball mount. Pop it in and hook up the trailer and go get something. And I can use it on any truck.
But I digress...seems a good option is buy a big inverter and connect it to my batteries, and let it idle all night. I do have the fast idle switch option if I need to excite the alternators. Plug the RV into the inverter and I can have the same 120VAC power @ 5000 watts that the generator would provide, without the noise or purchase price or fuel use of the generator.
I'm looking into the nuances of this but I like it so far.
You need to get on some rv forums. Irv2.com or similar. Talk about what you are trying to run, your goals, and the like. Idling your truck all weekend is not good.
Sent from my XT1254 using Tapatalk
I can tell you that idling the LML for a long period of time will plug the DPF. The truck has to be run at above 30MPH to clean out the DPF. This is right out of the LML manual...
9-12 Driving and Operating Diesel Particulate Filter The vehicle has a Diesel Particulate Filter (DPF) as part of the exhaust system to reduce vehicle emissions. The DPF requires a unique exhaust tailpipe with an exhaust cooler. The exhaust cooler mixes air with the exhaust to lower the temperature before it leaves the tailpipe. The DPF, the tailpipe, or other exhaust system components must not be altered. Inspect regularly and clean any mud or dirt from the exhaust cooler, especially where the exhaust cooler connects to the tailpipe and the openings where fresh air enters the cooler. The DPF will clean itself as part of normal operation. Several factors including fuel consumed, hours of engine operation and miles driven are monitored by the Engine Control Module (ECM). The self-cleaning occurs approximately once per tank of fuel. { Caution Permanent damage can occur to the DPF or related components if the required Ultra Low Sulfur Diesel (15 ppm sulfur maximum) or low ash CJ-4 engine oil is not used. This damage would not be covered by the vehicle warranty. Under certain driving conditions, such as stop-and-go traffic, the filter cannot clean itself. A message comes on when the DPF is dirty and needs to perform a self cleaning. See Diesel Particulate Filter Messages on page 5-14. For the filter to clean itself, the vehicle must be driven above 50 km/h (30 mph) until the message goes off. This will take about 30 minutes. See Diesel Particulate Filter Messages on page 5-14. { Warning During DPF self cleaning or during extended idling in P (Park), the exhaust system and exhaust gases are very hot. Things that burn could touch hot exhaust parts under the vehicle and ignite. You or others could be burned. Do not park, or idle for an extended period of time, near or over papers, leaves, dry grass, or other things that can burn. Keep the exhaust area clear of material that could ignite or burn. See Parking over Things That Burn on page 9-11 for more information. { Caution Extended idle should be avoided because the DPF system is not capable of self cleaning at idle. (Continued) Chevrolet/GMC Duramax Diesel Supplement (GMNA Localizing-U.S./Canada- Black plate (13,1) 7132827) - 2015 - CRC - 10/21/14 Driving and Operating 9-13 Caution (Continued) During extended idle operation, monitor the instrument cluster telltale lights and Driver Information Center for messages and take appropriate indicated action. Continued idling with the warning light/message on could cause irreversible damage to the DPF requiring repair and possible replacement that might not be covered by the vehicle warranty. You will also notice a change in the exhaust sound and engine idle speed. This is normal. See Vehicle Messages on page 5-12. If you continue to drive with the DPF warning message on and the exhaust filter is not cleaned as required, the malfunction indicator lamp and the ENGINE POWER IS REDUCED message will come on and dealer service is necessary. See Malfunction Indicator Lamp on page 5-8 and Engine Power Messages on page 5-13. Vehicles with DPF have specific fuel and engine oil requirements. See What Fuel to Use in The U.S. on page 9-22 or What Fuel to Use in Canada and Mexico on page 9-26 and Engine Oil on page 10-6 for more information on those requirements. Extended idling in P (Park) can cause exhaust parts and gases to become very hot. Keep the exhaust area clear of material that could ignite or burn. See Parking over Things That Burn on page 9-11. If equipped with a Power Take-Off (PTO), monitor the instrument cluster for lights related to the DPF. See Accessories and Modifications on page 10-1 for important information if you are considering adding accessories or modifying the vehicle.
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
