Finally got the step bar lights added. $6.00 for lights and $3.00 for a package of T taps. Already had some extra wire on hand. The lights are sold as a pair so I only used one per side. Pretty impressive little lights.
attachicon.gifIMG_20170414_191053473_zpsynpgztq3.jpgattachicon.gifIMG_20170414_195029460_zpsmpzg36fp.jpgattachicon.gifIMG_20170414_195219271_zps2fbf9iep.jpgattachicon.gifIMG_20170414_202030635_zpsbozyrg7r.jpg
Very cool. What did you tap into? Any chance you have links to the items you used?
Looks awesome!!! How do you turn the lights on? and yes how did you wire them in?
Lights were from ebay http://www.ebay.com/...=STRK:MEBIDX:IT, there are some cheaper, but this is a US seller. Tapped into the dome light wire under the dash using a T tap.
b30c79bf3b546fedf9ed73a5ae5cd096.jpg I added side clearance lights on mine!! Built all the brackets out of aluminum and also have strobes for our funeral home as well!!
  • Like 5
Did the AM/FM antenna relocation. So happy with the results and lead on the black plug that fits perfectly
What size is the plug for this mod? I need to pick one up.
I wish it was as easy as the NBS trucks. Bolt antennae down the inside of the fender and use the escalade cowl piece that didn't have the antennae. So clean looking.
Looks great
3/4", got mine at Lowe's, 2-pack, for a couple dollars.
Anyone know where to get a short antenna that has equal or possibly better reception than the long ugly stock one?
Or just use one of the round ones in the side of the bed ...
Found some strip LED lights at my local dirt Cheap. Basically what you can get from auto zone. Paid $7 for the strip $3 for a pack of quick connectors. I even stepped it up and spent another $4 on some good wire. Lol
How did you wire these up?
^what he said. Hillman company. They're located in the the hardware isle in the those blue pull-out drawers. 3/4 diameter is dead nuts a perfect fit but they don't exactly snap in place due to the way the trim piece is constructed. They come in 2-packs though so I pushed the first one in place and will see if just a "friction fit" holds it in place; especially at highway speeds. If it doesn't. I'll run a small bead of glue around the second one and try it again.....
I did my antenna mod about a year ago, didn't use glue, it's still in place. Most of my driving is highway, to/from work, and I always park into the wind. We get 30MPH+ winds, regularly, around here. Last week, the winds are over 60MPH. The winds are headwinds on my way home.
Just search the forums for under dash lighting. Very easy mod.
There's a grey wire on driver side a pillar you can tap into for them to go on with dome lights or you can go into Ignition power like I did for them to always be on when key is turned.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
