19 minutes ago, MeanGreen1911 said:
Bolt Trailer Hitch Pin/Lock  Part# 7023619
This lets you use your ignition key for your trailer hitch lock.  It seems to be made really well and helps keep an extra key off my key ring.
Approx $35 on Amazon https://www.amazon.com/BOLT-Lock-7023619-Padlock-Center/dp/B06ZZBJM23
Nice!
Edited by SS502
This is one of the first things I bought when I got my truck.  So much more convenient!  They also make a padlock version, that I use on my trailer and one on my shed.
Thank you for chiming in, I did order one off Amazon after I read about them on another website...great reviews from others too!
I've got one as well.  4 years now, and holding up great.  I put a little bit of white lithium grease on the part that goes into the lock a couple of times a year, and not a single issue.
Edited by OldBlue61
Spelling, d'oh!
8 minutes ago, chuckworkb said:
Is it generic to GM so anyone with a GM center cut key can open the lock?
No its keyed to your key.  When you first get it you put your key in and turn it and it sets it for your key.
Was messing around with my emblems and some vinyl. I put them on the truck, undecided whether or not I am keeping them on.1ae7f75f690acdf5ce340635e7350ec0.jpga864ab00c1647429ea8572fc43af3a16.jpg10f7b3aaf46d0adb450d4c78923759a1.jpg
Sent from my SAMSUNG-SM-G890A using Tapatalk
  • Like 5
I like it, makes your truck unique! Others may say it’s too much but I think it looks good. Now the Duramax crowd isn’t the only ones that have something there. I would probably try for just the chrome lettering on mine but only because it’s white. Oh and those wheels/tires and steps look great with that blue color, very nice truck ?
Edited by SS502
I like it, makes your truck unique! Others may say it’s too much but I think it looks good. Now the Duramax crowd isn’t the only ones that have something there. I would probably try for just the chrome lettering on mine but only because it’s white. Oh and those wheels/tires and steps look great with that blue color, very nice truck [emoji106]
Thanks for the feedback!
Looks good.  With all the black, the emblems in black chrome would have looked good as well.
Amazon just delivered mine today so I get to install when I get home. Ironically, was watching All Girls Garage (yeah I am a man pig) on Saturday and they had this product on their show...super simple, put your key in, turn it and that's it, it keys itself to your vehicle key and you're done. Thanks for this post!!
***Worked as advertised***
Edited by SS502
Added pics
anyone know a part number for the non-fish eye mirror???
On 1/5/2019 at 1:37 PM, Enough said:
Covered the distorted flush mount factory convex mirror in the driver's mirror with a proper 3" stick on convex mirror.
Stuck one on the passenger side too !! Got rid of that huge blind spot on the right side you could loose a full size truck in !!
Best 8 bucks I've spent in a long time !!5c3123905e9c3_ConvexMirror.thumb.jpg.c44cb9f32787fe3d0b30249486cbf28f.jpg
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 720 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
