As pointed out by Ravenkeeper, I misstated the pin number on the pink BCM block. It is correctly pin 26 on both blocks.
I have made the correction in the post.
This simple modification will cast quite a bit of light toward the back of the truck along the sides...and it's FREE
By adding a single wire to the BCM under the dash on the driver's side (at least in the 2016 and 2018 HD trucks) you can get the side mirror cargo lights to turn on whenever the truck is in reverse (when the truck is running) or the cargo light switch is turned on (when the truck is turned off).
You need to run a wire from pin connector 26 on the Brown BCM block to pin connector 26 on the Pink BCM block (see picture).
Following are some pictures of the amount of light put out with this mod.
Edited by grandpalarry777
You need to run a wire from pin connector 26 on the Brown BCM block to pin connector 25 on the Pink BCM block (see picture).
Actually, it is Pink-26 & Brown-26.  Pink has 27 opening, the pin closest to the Brown connector is 22.  Using a diode will only allow the cargo lights to come on with reverse or reverse lights to come on with cargo lights, if you don't want to have them all on in by both triggers.
Edited by Ravenkeeper
Meanwhile,........ back to the $50.00 and under mods.
For the new round-headed flapper valve:
2 ea. screw clamps,
1 pc. 3/4"x3" scrap strap.
Rotate the flapper valve fully clock-wise and clamp tight.
Enjoy the exhaust tone.
You are a freaking genius. I looked at that stupid flapper for 30 minutes and could not figure out how to clamp it open. Mine is rattling at idle. Cant wait to clamp it open. Tuner arrives soon to turn off v4 anyway. Thanks.
2 ea. screw clamps,
What kind of tone?
Just a little deeper, but works best with the AFM tuned out to avoid the heli-chop sound when it loses 4 of the cylinders you paid for.
I like that "freaking genius" thing.  Might have to adopt it into the persona.
12 degrees outside in the Home Depot parking lot, I did the Mr. Freaking Genius fix for $5.98. Less than 2 mins. I already have v4 turned off. Definitely a louder, deeper note to the stock exhaust, and the valve no longer rattles at idle. THANK YOU.84463393e8c272d8652c4b6ef898cf83.jpg
  • Haha 1
Now that, boys and girls, is true dedication to a "Cheap-@$$" mod!
12 degrees!  Brrrrrrrrrrr!
  • Haha 1
On 3/23/2019 at 4:04 PM, BigBlueLB756 said:
Are we done now, or are there more?
Hope we're not done.  Still looking for a few more inexpensive mods to do.
i've got stuff planned... just need some time!!  my wife had to get foot surgery about a month ago.  still can't put any weight on her foot so i've been doing everything (and she has been going NUTS on the couch).  it wouldn't be too bad except that we've got two young kids (6 and 3.5 yrs) - so that keeps me hoping!!  my wife should be good on her foot again in the next couple weeks!!  can't wait!!  ha! ha!
I was on her side of your situation, July - September, with my broken foot from my head-on collision.  Our unpacking from the move, the week before the accident, was on hold for the most part, plus we had to add an additional month to our storage locker, because of it.  Both of my kids are teens, daughter (teen-driver) was "Miss Edwards AFB for 2018," so she had things to take care of all summer long, and our son went with her to some of her events, whose friends would swing by and steal him away to get him out of the house, from time to time.  We're almost done unpacking, most of what's left to unpack (in the garage) will be donated to Goodwill or AMVETS.
  • Like 4
I swapped my door handle end caps to make a thief's job just a little harder. Eventually I will get a new end cap and replace my drivers-side rear door cap so it wont have a hole but for a super easy thing to do here is my thread...
2 minutes ago, Thejet07 said:
Why do I have to stumble upon threads like this? More money spent
LOL...mine above is free for the most part :D
Well...I picked up a new right side handle (part number 22923598) off eBay for $20.69 with free shipping so I will swap out the cap without the key hole when it gets here. I had a eBay coupon so I used it and got a pretty good deal, now I will have a spare handle should I ever need one :thumbs:
Edited by SS502
Added part number
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
