Recently bought a 2014 Silverado LT w/ 5,3L and 6-speed trans(4wd crew). Truck has 110,000 miles on it, but appears to be lightly used and truely all highway miles. I have been driving it for a week now w/ no issues but this morning on the way to work under light driving the truck jerked and the engine light and the traction control light came on. They went off about a mile down the road but truck now seems to shift hard. Is this a sign of transmission problmes? Should the dealer have been able to see this problem by reading recent codes? I was told there were no issues and the truck had just been scanned and had no codes in the record.
Any ideas on the problem? Any comments on if i got screwed by the dealer? Are there issues w/ this transmission? What should i be doing to remedy or extend the life of the trans?
Any thoughts would be appreciated.
Thanks
I have a 2007 that has shifted ereatically from day 1 and now has 180,000 miles without a failure, maybe chevys just shift this way?? ughhh.....
I'd bring it back to whoever you bought it from, and make them fix it. If they won't, make 'em buy it back and get another truck elsewhere.
Obviously, you need to check the code that lit up your check engine light first.
Sounds like what just happened to mine, turned out to just be a spark plug wire that popped off, so one cylinder was not firing. The jerky transmission feeling was from the engine bouncing around at low rpm. They replaced the plug wire, it took 5 minutes to fix.
Until you know what the error code is, you have no clue on the fix.
A 2 year old truck with a 110,000 on the clock is not lightly used ( might be considered well maintained). Normal driving miles is between 12,000 and 15,000 miles a year. I have an 2009 that has 3000 miles on it. That would be considered lightly used.
Got the codes from a scanner I barrowed, turns out there were 4 codes. U0073 (CAN Bus Communication), U0401, U0102 (Lost communication w/ transfer case), U0140 (Lost communication with Body Control Module). They all seem to point at the same thing either a worn wire or bad plug and there is a GM bulletin concerning this and I plan to follow up w/ my local dealership.
My next question to the forum is could these codes have been cleared so the dealer could not see them? Or would their scanner have showed them even if someone recently cleared them? I specifically asked if it showed any codes or transmission problems and was told NO. I bought the truck from a private seller but had a dealership local to him perform an inspection, supposedly the most thorough I could purchase….at a minimum if he should have been able to see these codes I want my money back.
And YO, Duelin, thanks for helping me with my problem. A 2009 w/ 3000 miles….do you use it to pull parade floats? I don’t think that’s lightly used, I think that’s unused. You would be better off financially renting one from home depot when you need to pick up your 2 bags of groceries. I will look you up when I need help choosing a wax.
Those codes could just be in memory - if they were active, you'd have a whole host of issues. Dealers usually never clear them for whatever reason.
When I got my Autel, I hooked it up to my truck and found 18 U & B codes. Could've all been triggered by the body shop that repaired scratches caused by an idiot that wanted to drag race the second I started to pass him, or they could've been in there from day one. Hard to say.
No! don't pull any floats don't want to over work it. Its not a work truck just an LT. Anyway I haven't been to a parade since 1962. I use it to test batteries. I will a buy new battery and let it set until it goes dead. Then I buy another battery. When I get the results from all of these dead batteries I will post the results of which one is the best. As for wax I use Beacon Vinyl Floor Wax. :)
Edited by Duelin
  • Haha 1
These BUS systems go crazy if you're having power issues. Get the battery tested before you do anything and then the alternator.
I ran the battery down once on a 2013 Traverse left a battery box plugged in but it went totally stupid until I had the battery charged back up.
Throwing codes, Putting windows down, the alarms went off, I just let it run until it was charged the thing probably would have killed me if I tried to drive it.
Just eliminate these things first then dig into the issue.
Hello Muffler Bearing,
We regret to hear that you are experiencing these concerns with your transmission. We understand your desires to have a reliable ride, and apologize for any inconvenience caused by this situation. We would be more than happy to reach out to a dealership on your behalf to see what repair options you may have. Please send us a private message if this is something that interests you.
Kindly,
Julianne M.
GM Customer Care
Edited by GM Customer Service
  • 4 months later...
Update to this issue, dealer has hit me for spark plugs, plug wires, and a fuel system cleaning. (and diagnosis fee of course). The codes i posted originally were apparently left over from who knows when.... and the dealer cleared them. The code that is reoccuring has been a cylinder misfire (either random misfire or cylinder #7). Once the code pops up it goes into limp mode and has all the symptoms i described above.
So what i am finding out is that the real issue (i believe) is the loud ticking i was told was normal and just the way the CDI sounds. I do not believe this!!!!. I have been told by a "non-dealer" mechanic, the issue is the lifters going bad that are associated with the Active Fuel Mgt system. He tells me he is fixing these on a regular basis, and the dealers are refusing to admit the problem. Has anyone heard of the ticking bing lifter issues associated w/ the AFM system???? Tearing the top of the motor apart is not a cheap thing to be chasing........ Any help w/ the ticking/misfire/AFM system issues would be greatly appreciated!!!! Thanks, (Even Duelin)
https://search.yahoo.com/yhs/search?p=afm+lifter+failure&ei=UTF-8&hspart=mozilla&hsimp=yhs-002
All you ever want to read (but probably don't want to know) about AFM lifter failures
I just had all 16 lifters, cam, oil pump, etc replaced due to a lifter on #5 cylinder (non-AFM lifter) failing and scoring the cam. My truck had the ticking for a while, and finally broke down and installed the Range AFM disabler. Then one day, as I was pulling in the driveway, it started chirping and sounded like a belt chirping. Pulled the belt off and it was still chirping. Got to reading up and all signs pointed to a failed lifter. Bought the AFM delete kit from TSP and dropped it off at a local shop for the repairs. They called me and asked me to come by so they could show me the issue. The roller lifter was pitted and the cam was scarred up from the pitted roller.
http://i.imgur.com/8Qizg9I.jpg
http://i.imgur.com/auxz5Fz.jpg
Edited by hammerhead611
I would not be to worried about a slight click, these DI engines just make some odd noises. I have never seen a GM +2014 DI engine that did not have some kind of slight click about it. The last quiet V8 I had was a 2006 5.7 you could not even tell it was running/idling with over 150k on it.....but it got about 12mpg and rode like a log wagon LOL
I do agree with a lot of others though in wondering if these +2014 DI engines will hold up at high mileage (+150k). Awesome technology if it actually holds up well long term. How much is a crate engine for one of these +2014 GM trucks?
  • 4 years later...
My 2014 has 249k and just started with this misfiring c/ stuttering, threw a set of plugs, first set, and wires no relief. No idea what’s wrong other than rebuilding the top. Overall been a hell of a truck!
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
