Well I installed the LED backup bulbs today and tested them out tonight.  I’m sure they’re not as nice as having the bumper mod lights, but the LED’s are a vast improvement over the stock bulbs.  Not sure whether it will be worth it to do the modification given how much better I can see (through the backup camera) than with the stock lights.  Very happy with the light output.
Of course installing the new bulbs caused a problem (broke one of the posts that hold the light assembly to the truck.  But, that’s another thread.  The LED’s are nice.
On 12/10/2016 at 4:22 PM, gmdog2 said:
I'm sorry. I didn't take any pics of the install. You really don't have to remove the steps if you have a some long needle nose pliers. Once you install the light/bolts into the holes, getting the nuts/washers on the back become the challenge. That's were I just finally used long needle nose pliers and the put the washer on, then the nut, then tightened it all down. Run your wires up to your taillights and tap into your reverse lights. As far as wiring, I just use a tester, find the hot and negative, then wire them up..hope this helps.
so im just getting ready to install a 2014 bumper on my 2005 1500, just ordered it, i figure why not try to mock up a light install just like this, and im going to do a parking sensor hole light install also, all while off the truck before install. My main worry is if i do the pocket installs while off the truck i may hit something with the lights upon installing the bumper, any ideas or concerns? I know this is an old project now.
  • 3 years later...
Here is my interpretation of this. Diode Dynamics SC2 utilizing their 7-Pin harness adapter.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
