Running Boards 4" or 6"
bnwbass
All,
Just picked up 2015 LTZ crew 1500. I need to install running boards and was wondering if anyone installed 4 " vs 6" and any pros/cons between them.
Thx
Bw
I like the 6" myself, both the way they look and the more secure footing getting in and out of the truck.
I also prefer my 6" ones because they protect more from tire kick-up
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
