Grade braking
I have a 16 Silverado with the 5.3, 6 speed and 3.08 gears. I just purchased a travel trailer with a max weight of 3500 pounds. My first long trip will be to Michigan through Tennessee. I have never towed a trailer through mountains and I am not sure how the grade braking works. Monteagle is a little intimidating, so any advice and wisdom from experience is appreciated.
It just automatic in tow mode I believe. It just down shifts to save your brakes.
Grade braking does nothing but downshift the transmission, often I will turn it off.
If your truck does not have factory brake controller you need to get a good one and adjust the gain to you liking for the trailer being towed.
The grade braking simply uses the engine to help slow the vehicle it is a useful feature and is just in addition to your trucks regular brakes and of course the trailer brakes. Monteagle is not all that bad as far as grade the biggest issue is other drivers that want to speed demon around you like the morons that they are. My advice would be to stay in the right hand lane as much as possible / keep the grade braking active to help save your brakes / set your trailer brake controller so it is evenly matched with your truck brakes and simply keep your speed down. You will be fine as you are nowhere near max tow capacity on your truck.
MyFavTruck said it very well. I just want to emphasize the point of driving at a speed comfortable for you. Don't worry about what other drivers are thinking about your driving and periodically pull over to let the people behind you pass. Your confidence will improve over time.
Two levels.
Powertrain grade braking. This is on all the time unless you hold the tow/haul button for 5-7 seconds.
Tow/Haul grade braking. Much stronger/more aggressive form of powertrain grade braking. Helps when slowing heavy loads/trailers.
Your case I would experiment a bit. Hills, leave Tow/Haul on and in D. You can experiment with the M/L range shift if you want but it does turn all grade braking off.
I'd leave it on flat ground as well as the 3.08 gears with a load you will never touch 6th gear with it off IMO. 5th gear is a good sweet spot with 3.08.
When in T/H and cruise it will grade brake - towing or not.
Or shift to M and manual down shift anytime - towing or not.....
Worked much more aggressively with my Duramax - but the 6.2L does try.........
:driving:
Normal Mode Grade Braking
If equipped with a gasoline engine
and an automatic transmission,
Normal Mode Grade Braking is
enabled when the vehicle is started,
but is not enabled in Range
Selection Mode. It assists in
maintaining desired vehicle speeds
when driving on downhill grades by
using the engine and transmission
to slow the vehicle. The first time
the system engages for each
ignition key cycle, a DIC message
will be displayed. See Transmission
Messages 0 152.
To disable or enable Normal Mode
Grade Braking within the current
ignition key cycle, press and hold
the Tow/Haul button for
five seconds. When the button is
released, the requested mode
change is made. A DIC message
displays. See Transmission
Messages pg 152.
For other forms of grade braking,
see Tow/Haul Mode 0 273 and
Cruise Control pg 287
Tow/Haul Mode Grade Braking
Tow/Haul Mode Grade Braking is
only enabled while the Tow/Haul
Mode is selected and the vehicle is
not in the Range Selection Mode.
See “Tow/Haul Mode” listed
previously and Manual Mode 0 270.
assists in maintaining desired
vehicle speeds when driving on
downhill grades by using the engine
and transmission to slow the
vehicle.
If equipped, on vehicles with a
gasoline engine, to disable or
enable Tow/Haul Grade Braking
within the current ignition key cycle,
press and hold the Tow/Haul button
for five seconds. When the button is
change is made. A DIC message is
Messages 0 152.
On vehicles with a diesel engine,
Tow/Haul Mode Grade Braking can
be enabled or disabled by pressing
the Tow/Haul Mode button. Use the
exhaust brake and Tow/Haul Mode
for maximum grade braking.
Using Cruise Control on Hills
How well the cruise control works
on hills depends on the vehicle
speed, the load, and the steepness
of the hills. When going up steep
hills, pressing the accelerator pedal
may be necessary to maintain
vehicle speed.
While going downhill:
. Vehicles with a 6-speed
automatic transmission and a
gasoline engine have Cruise
Grade Braking to help maintain
driver selected speed.
Cruise Grade Braking is enabled
when the vehicle is started and
cruise control is active. It is not
enabled in Range Selection
Mode. It assists in maintaining
driver selected speed when
transmission to slow the vehicle.
To disable and enable Cruise
Grade Braking for the current
hold the Tow/Haul button for
five seconds. A DIC message
Messages 0 152.
. Vehicles with a diesel engine
have Cruise Grade Braking
enabled when Tow/Haul Mode is
on, the exhaust brake is on,
or both are on.
It looks like you have never towed on steep grades...... So here is a little info for you in case you don't already know.
If you find yourself having to use your brakes to slow down going down hill, then you need to downshift until you don't...... If your braking on and off all the time down hill you will smoke your brakes, and then you won't have any brakes and wreck..... Be smart, and let your engine do the braking for you.
Good luck
The manual section quoted abpve is exactly what I said - in far less words........
:driving:
redwngr if the wall of text was for me I have read the manual. My question is what actually causes the grade braking to engage, what triggers it to do a downshift?
