Help Needed,,,,
hello all , I purchased a set of the Tri-mode steps for my 2015 Sierra Denali and followed Phil’s diagram and made my harness but I cannot get them to work correctly. Thinking I maybe Have done something wrong I made a new harness checked it over and over and I bought a new module and to my surprise it continued  to do the same thing. When I enable them and open a door they slide all the way to the back. Today I had tech connect his computer thinking it might need to get flashed or programmed and after 4 hours he could not get them to work. I’m at the point where if I can’t  get them to work they are coming off. I would really appreciate any ideas. Thanks in advance.
Are both of the running boards doing this (driver AND passenger)? What if when they are retracted and you press the foot switch on the end of the running board, does it swing out to the rear position? If pressed again, does the running board fully retract?
There is a Hall Sensor (basically a sensor that detects magnetic fields) inside each motor that senses the position of the running board. Not entirely sure what happens if these go bad or if these sensors are actually replaceable. I would think this is a sensor issue since the running boards do extend and retract, they just don't extract to the proper position when you open the door.
As I said the Hall Sensor is inside each motor and needs to be wired up to the control module. Each Hall sensor uses 3 wires, a +5V Reference wire, a ground wire (or Low Reference), and the sensor output wire. These go to the X2 connector on the module (the 12-pin connector) and they occupy pins 1 thru 6 of said connector.
On the motor assemblies themselves, there is an 8-pin connector for each, and the Hall Sensor uses three of the 8 connections (pin 2, 3, and 4). You can see these in the Upfitters Body Builders Electrical manuals for the Sierra 2016 and above.
I would double check these wires are correctly pinned, as if they are not the sensor would not work to tell the control module where the running board position is.
Good luck and keep us informed on what you find.
Xenawise
On 4/4/2020 at 10:32 AM, chicano_de_atl said:
Hey guys I have a set of running boards off a 2018 Denali for sale there in good shape. Located 40 min north of Atlanta I ended up selling my truck before I installed them
Do you still have these ?
If anyone is interested In a pair of the GM OEM TRI MODE BOARDS. for a 2019-2020 GM. I have a set.
purchased them for my 2017 and was told they were my year. But when they arrived we realized they were 2019.
only on the original truck for a few months. Very minor scratches. Great shape. 900$ plus shipping. Pictures to post soon
  • 4 months later...
I got my tri-modes wired up today. Thanks to Phil Gamboa for the harness and the help getting it wired up.
  • 4 months later...
So confirmed that the T1 steps are not compatible with our K2s?
  • 4 months later...
After purchasing a set of power boards from a 2017 GMC, I contacted Phil for one of his harnesses.  After watching the video, decided to just contact him to do the install.  Swapped out the factory GM boards for the articulated boards on Saturday.  Went to Phil's on Sunday, one hour later they were working like they were always there.  The harness install looks factory.  Outstanding product and a very smart guy.
Phil is the best in the biz! Looking forward to some pictures in the "what have you done to your K2 today" thread!
  • 4 months later...
Has anyone in the L.A. Los Angeles California area done this Retrofit yet ?
  • 2 years later...
Hi guys,
I have just purchased a 2022 "Refresehed" LTZ and it came stock with the fixed step assists. I then found a good deal on the articulating running boards on FB marketplace but missing the harnesses required. If they came off a 2024 High Country 1500, are there control modules and harnesses available to purchase through Phil? would the installation be the same as the youtube video?
On 5/13/2024 at 12:46 AM, agarc44 said:
Hi guys,
You're kind of out of the element here.
This is a forum for K2s and not T1s.
Still, you can reach out to https://harnessdr.com/ for some information.
  • 4 months later...
@pgamboa
Thanks Phil for being such a rock star!
I just purchased a set of these running boards for my 2018 gmc 1500 elevation. The seller let me cut the plugs off his truck. (crazy guy lol) I am an automotive electrical technician and wiring is not a concern however, the running boards I purchased may be faulty.
The drivers board wont move freely by hand so I cant even pull it apart to bolt the unit on to the truck. The passenger board articulates freely off of the truck by hand which makes me concerned I may have a seized unit on the drivers board.
How should these move when power isn't attached?
I noticed the round pivot point on the drivers side board, closest to the rear tire, has slid down below where the wear line is for the pivot. I'm wondering if the old owner attempted to remove the running boards incorrectly and it just needs to be moved up to move freely again. Is there torque specs somewhere for these bolts as well?
Thanks for your time.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
