2019 GMC Terrain - What's New, Changed, & Removed
Zane Merva
Executive Editor, GM-Trucks.com
6/4/2018
GMC is about to roll out some brand new options for their 2019 models. This week we're focusing on all of the changes that General Motors is making accross all of their brands for the new model year.
Check out our other "What's New For 2019" Articles
Here's what's new for the 2019 GMC Terrain
2018 Options That Have Been Retired
  •      Exterior color (GJB) Mineral Metallic (deleted mid-2018 model year)
  •      (UVH) Surround Vision (replaced by [UV2] HD Surround Vision)
  •      (PDR) SLT Chrome Accent Package (replaced by [PDV] Bright Accent Package)
  •      (PDM) LPO, Black Accent Package
New Features, Colors & Options for 2019
  •      Exterior color (GS6) Smokey Quartz Metallic
  •      (KSG) Adaptive Cruise Control, full-speed with Stop/Go
  •      (UKJ) Front Pedestrian Braking
  •      (UVB) HD Rear Vision Camera
  •      (UV2) HD Surround Vision
  •      (WJP) Black Edition, includes (PJM) 19" gloss black aluminum wheels, (V22) darkened front grille, (V2P) black roof side rails, (VWD) black GMC center caps with black GMC lettering, LPO, black exterior accents, black mirror caps and black exterior badging
  •      (CWB) Chrome Package, includes (PJH) 19" machined aluminum wheels with Gray painted accents, (GGC) unique chrome grille with chrome surround, (DP9) chrome mirror caps, (D7A) body-color door handles with chrome surround and Bright side rails
  •      (PDB) LPO, Dark Accent Package, includes (SJ9) three-bar grille with Black surround and Charcoal insert, LPO, (S4X) Black painted mirror caps, (RXX)Black rear license plate applique, LPO and (RYQ) front and rear Black fascia inserts, LPO
  •      (PDZ) LPO, Interior Enhancement Package, includes (VYW) premium carpeted floor mats, LPO and (S03) embroidered front row headrests, LPO
  •      (PEF) LPO, Floor Liner Package, includes (RIA) front and rear row all-weather floor liners, LPO and (CAV) integrated cargo liner, LPO
  •      (SFZ) LPO, Black GMC emblems, front and rear
Small Changes In Trim & Packaging for 2019
  •      (Y29) Infotainment Package I now includes the new (UVB) HD Rear Vision Camera (replaced [UVC] Rear Vision Camera
  •      (BGP) Driver Alert Package II now includes the new (KSG) Adaptive Cruise Control and (UKJ) Front Pedestrian Braking
  •      (WPR) Advanced Safety Package now includes (UV2) HD Surround Vision (replaces [UVH] Surround Vision)
  •      (PS1) Comfort Package no longer includes (K4C) Wireless Charging, which is now standard on Denali
  •      (UDD) 4.2" multi-color driver information screen is now standard on SLE and SLE Diesel (was part of [Y29] Infotainment Package I in 2018MY)
  •      (UDD) 4.2" multi-color driver information screen includes audio, phone and navigation capability on SLE when (Y29) Infotainment Package I is ordered and standard on SLT and Denali
  •      (UVC) Rear Vision Camera is no longer available on SLT and Denali (replaced by [UVB] HD Rear Vision Camera)
  •      (K4C) Wireless Charging is now standard on Denali (was part of [PS1] Comfort Package in 2018MY)
  •      (PDG) Cargo Package no longer includes (CAV) integrated cargo liner, LPO
  •      (SJ9) Three-bar grille with Black surround and Charcoal insert, LPO is no longer available as a Free Flow option (part of [PDB] Dark Accent Package, LPO only)
Good grief.  Once upon a time Chevy and GMC made good looking vehicles, something most men would not be ashamed of driving.  And then they come out with the 2019 Sierra and Silverado, and this thing.  :puke:
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
