5 minutes ago, Chance1025 said:
Nice. I really like the look. Been thinking about it myself. How much did it cost you? I was quoted $425 for a wrap. Seems a little high.
Yes that’s really high.  I’m in Kentucky  $300 around here and that’s completely disassembled and painted professionally.
Oh nice! Where in KY? I’m in Louisville.
Yea your not far.  Little over hour and half .  Scott’s Collision In Mt Sterling .  I saw a white lifted trail boss (same lift as mine) with the bumper painted white and it looked really good.   My lift I got out put on in Lexington at Luckys Autosports.  They do a really good job and lift 3-4 trucks a week.  Ive got the 4” Rough Country / with the stock 2” trail boss lift comes out to 6” suspension lift.  I’ve got 20’s/ 35x12.5 .  I’ve got my stock black trail boss wheels / tires Goodyear duratracs  up for sale too if you know anyone around here who wants any $1400.
Std bed came in handy
Cleaned our attic. Having a garage sale for a fundraiser for my sons baseball team
  • Like 4
Gonna have to start investigating new brake pads [emoji1787]
In all my previous GM trucks the rear pads always wore out faster. I never changed a front set on my 2000 or 2010
Yes I know this is an issue and there is a fix
Shit I’m between both of you guys I’m in Frankfort.
Lucky is a good friend of mine got my lift wheels and tires from him did the install myself. But I have a 18
Yeah man. That bed is awesome. Deep and big.
Very nice.
Small world. I’m in Frankfort as well.
Love seeing trucks being used as trucks!
We cleaned out our small storage area today. What would have taken 3-4 trips in the car was done in one trip and we didn't even cover the floor of the bed. This thing has gobs of capacity. Unfortunately forgot to take pictures, too busy doing manual labor. ?
On 8/15/2019 at 5:43 AM, rmkmb said:
2'' LEVEL,1'' REAR BLOCK
285/60/20 TOYOS'
Got any pictures? I’m liking the sound of what you did...Thanks!
Edit: Disregard, I found some of your pics. Looks nice!
Edited by ausomecasey
    • 87 down as low as $5.14 here... winning!
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
