6 minutes ago, Dali555 said:
Which one is that? How is it installed?
It is an Aeroskin  made by Lund part # 322168, smoke in color.  $48 on flea bay. It is held on with 3M tape. Had one on my TB and never had any trouble with it.
Got an appointment Tuesday to get the fog lights programmed, think I'm done with things for a little while.?
Got 'er snowed on for the first time taking the Boy Scouts up the mountain to the Klondike Derby - about 4 inches of wet heavy sticky snow... got away without chains.. road was pretty clear...
  • Like 4
22 hours ago, Thunderflight said:
Budrug XLT, Lomax tonneau and Borla S-type
How do you like the Borla?
I know you didn't ask me, but I have the Borla S-type as well, and LOVE it.  Perfect deep tone, without being to loud.  It's loudest at cold start obviously.
I got rid of the dealership logo’d rear mud flaps and installed the GM molded splash guards. I also removed the vinyl letters on the tailgate that the dealer installed. I also stopped by the Xpel dealer to talk about PPF and ceramic coating.
Get the ceramic coating for sure. Best to have it done while truck/paint is new.  I had mine done in November when I bought my truck, and it still beads up every time it rains. I got a 2 year coating, and will get it done again after 2 years.  Worth every penny.  Truck looks brand new every time it gets washed.
On 4/15/2019 at 2:54 PM, Trailboss75 said:
was this easy to do or do you have to pull the entire console out to get wire underneath?
You could've bought a multi port usb
Got the fog lights programmed this morning, everything seems to be working as intended. Dealer never charged for the service either.
Learned to not drop a 1/4" drive w/ 10mm socket into the engine compartment when removing the nut on the negative battery terminal...
Got it out though.
  • Haha 1
Programmed?? What exactly did they do?
Tech had to call GM and give them the activation code that came with kit. GM then sent tech a text saying that what ever they have to do is done. Tech then connects computer to the OBD port and goes through a series of prompts, after that everything worked, fog lamp icon on dash also comes on. Took longer for GM to text back than anything. I already had lights and all wiring done before I took it in.
Apparently the fog lights require a dealer "flash"
Got it out though.
I recently dropped one of the air box screws when putting my AEM filter in and it took prayer to find it.
    MASONV88888888
    MASONV88888888
  • Who's Online   0 Members, 0 Anonymous, 1,552 Guests (See full list)
    • I have 2 choices.
