43 minutes ago, irkburgles said:
Anyone have a part number for black wheel cap and lugs that fit the AT4 18” wheels?
PM "Transient", he bought a set, he may still have the part #
Installed the new style off road assist steps today. Not sure if I like them. Didn’t have assist steps on my 2016 or my 2019 and never really was a fan, but I got these for 300$ so why not. They have a great texture, and say silverado like the sport steps but low profile.
1 hour ago, irkburgles said:
Anyone have a part number for black wheel cap and lugs that fit the 2019 AT4 18” wheels?
I got mine from Amazon.
https://www.amazon.com/gp/product/B089D6YV8H/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Titled - steel.frame.motor 83mm(3.25in)/73.5mm(2.89in) Colorado (2008-2012) Tahoe (2008-2014) Wheel Center Caps Black for #9595383#9597109#22837060 4pc
Fit like a glove.  And got here way quicker then they quoted me.
- X
Headed to the dealership to pick up the parts for auxiliary switches.
I don't know that guy, but he sounds like a a-hole. [emoji1787][emoji1787][emoji1787]
For clarity, I have a Trail Boss. I can give part numbers for black lug nuts, but not GMC center caps.
  • Haha 1
Where did you find them for 300? For what it’s worth I think it looks good
Sprayed the salt off today and found some water around the back window [emoji35]
Add me to the list [emoji2959][emoji2959][emoji2959]
Me too man, this is out of control.
On 1/11/2021 at 11:18 PM, wepiii said:
Would love to see some pics of the wireless charger install. Also, how are you not rubbing bad? Wheel spacers? I have 295/70’s, which are essentially 34.5’s and 11.6 inches wide, and if I was anyyyy wider, I would rub bad.
Also, if you have the RC 1.5 level, check out the RC control arms for their 3.5 inch lift kit. I installed them on mine with the same level and the ride is so much better
Are you so close to rubbing due to the RC upper control arms? Or are you rubbing on the liner and mud flap?
- X
You can get them with the bowtie....cheaper
https://www.ebay.com/itm/402201508063
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
