12 hours ago, wepiii said:
Would love to see some pics of the wireless charger install. Also, how are you not rubbing bad? Wheel spacers? I have 295/70’s, which are essentially 34.5’s and 11.6 inches wide, and if I was anyyyy wider, I would rub bad.
Also, if you have the RC 1.5 level, check out the RC control arms for their 3.5 inch lift kit. I installed them on mine with the same level and the ride is so much better
I didn't take any pics of the install. I followed this video with the only difference being is that I used the Apple charger which I had to cut a round hole in the center of the console lid for the charger to fit. I did not rub without the leveling kit. I am not sure how. In all my research there are people that rub and some that don't. I took the plunge and was going to make the necessary mods to make sure it did not rub, I ended up not having to do anything. My guess why some people rub and some don't with exactly the same setup is these trucks are not all built the same so I am assuming there are some tolerances that are not exact on each truck even with identical trims and options.
On 1/10/2021 at 10:46 AM, Kickerz71 said:
Looks great - any rubbing with the lift and tire size?
With factory wheels you can fit 35's with little to no rubbing on the Silverados.  Its when you go aftermarket wheels (different widths and different offsets) that you encounter rubbing issues with 35's
Finished up the release version of our automatic heated and cooled seats with auto steering wheel heat :)
  • Like 5
What’s your website url so I can take a look at all your development features?
Www.whiteautoandmedia.com
Facebook.com/whiteautoandmedia
Not sure why you want the heated seats and steering wheel to stay on once the inside gets warm as those will get to the same temp as the inside cab so really no use for it. I see early burn out on the elements for the seat and steering wheel from them being on all the time based on the temp setting.
They dont. It drops down heating/cooling levels progressively until it turns off. Its basically designed to take the chill/heat out of the surfaces and thats it; you can see it ratchet down and shut off in the video we just accelerated the process by dropping the target cabin temp as we didn't want to wait several minutes.
Edited by GTPprix
The 21 Denali will turn on the heated or cooling seats, along with the steering wheel based on outdoor temps when you remote start the truck. If'n it is toggled on, in the center stack. You can manually shut them off as normal, when the desired comfort is reached. You might ask GTPprix if works in the same manner.  It is a great feature in the winter.
Today was a good day to do some mods the truck in the shop. 60mph gusts, but the cattle have been fed.
Washed the truck, tinted front door windows and a windshield strip, installed matte black in-channel window visors, wired in Boostautoparts, spot to high beam and the all lights on high kits. Replaced the plastic skid plate with the aluminum version on the front, and installed the transfer case skid plate. Took measurements for homemade skid plates for the fuel filter area, def tank and the fuel heater hoses.
  • Like 3
 Washed it and ceramic sprayed it. Took the elevation badges off. The Sierra is next. Going to keep the GMC. Loving the color so far!
  • Like 5
Got my Range DFM Deactivator along with my Rough Country roll up tonneau put on today!
How has your tonneau cover held up? Any more pictures. I have one on order but they are on back order until mid February.... thanks COVID!
Drove it for the first time in two weeks. Been in quarantine after testing positive, today was the first day I could leave the house. So groceries and just a drive.
Got the front windows tinted to match the rears (I believe 15 or 20%)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
