6 minutes ago, Chance1025 said:
Took her for a ride around the farm to the back of the property!561d8f29cd26809edf4344d778d81391.jpga98c23b91a121be738231b02e3761104.jpg
Which in track window things did you get?.. can't think of the name lol
They are the “factory” ones. I got them from the GM parts department at my dealer, with the points from my truck purchase. But they are actually made by EGR. They were the “smoke” in channel rain guards.
Ok cool thanks yeah I like the in track ones. Do you like the smoke ones the best? Were you able to look at the other options? ie: black, smoke, etc.
Unfortunately no. I had to order them in. They have flat black too. Which would prob look pretty good as well, I would think.
So I am assuming the smoke is just a semi transparent, semi gloss black? And the flat black is maybe opaque?
On 9/4/2019 at 8:35 AM, AJMBLAZER said:
Ok. Thank you.
Did you have any of the warpage and window operation issues others report?
I did at first, then I realized that they weren’t sealed correctly. So I wedged wood shims between the window and the vents over night and that fixed it. Now they don’t warp and the auto window up works fine. No issues since.
18 hours ago, michael betz said:
About an hour.
Came out nice. Thank you for your assistance.
Organized my toolbox
Got these cases at harbor freight one has tie downs and the other tools
Ryan B.
Black widow wheels, ridge grapplers, Avs window screens and northern tool toolbox. Love this truck, HUGE upgrade from my 2013 LT 2wd.
Edited by NCD
  • Like 6
I’ve been debating about what to buy first between the fender flares and hood mount spotlights. Are those the spotlights the ones from zroadz and are the fender flares rough country? I’ve been trying to decide between rough country, bushwhacker, and authentic SCA black widow fenders (SCA does sell just the fenders for anyone interested, unpainted for $500)
The lights and the flares are Rough Country
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
