Ceramic tint 5% on all windows. 70% tint on windshield, 30% on sunroof. Replaced the GMC logos with black ones. Removed the tailgate Sierra.
Where did you get the tint done? Looks awesome!
Thanks! Tint World in Katy Texas.
2 hours ago, Trailboss75 said:
Had my exhaust tips Hydro -dipped in carbon fiber!  Turned out awesome, now just need to get them installed! :)
quality job done there! Nice choice
How does the material feel, think it'll last?
I received and installed the Boost Auto - Fog Mod today. Quick and easy.
First night I had the truck I thought my auto headlights were broken. Surprised I had to mod this to get it to work as I expected it already should.
What does this mod do? Allow the fog lights to be on and Auto Headlight still function? Are the fog lights on all the time?
Ordered the roto-fab cold air intake [emoji16]
Ryan B.
Yes, it allows the fog lights to be on with the auto headlights. When the high beams turn on, the fog lights also go on to make it as bright as possible.
Hat tip to whoever posted about the mod here...
http://boostautoparts.com/products/6hi
  • Like 4
Thanks,
Just ordered.
14 hours ago, eppieguy said:
Thanks,
Just ordered.
That's a great mod, I just ordered one too.
I watched the video though, and questioned why the hell they didnt add an extra 1" of wire on either end of that connector. It's at quite the angle and he struggled to make the second connection ?
She's almost done!
Got the Tonnue Cover Done. Got the REV industries Hard Top cover. It's a rebranded BakFlip as it appears to have the exact same design.
Wheels, Tires and Running Boards this Friday. I can't wait to wrap up this build.
For Now [emoji6]
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
