On 10/19/2018 at 12:09 PM, Sierra Dan said:
Well around here in the KC area, dealership Sales departments are lacking in the information department.
Not just GM, but others as well. I will say Honda and Nissan dealers around here have the most knowledge about their vehicles. Still not perfect, but way better than GM
Go to Erik Fish at McCarthy-Morse Chevrolet in Overland Park. Super cool, laid-back, salesman that knows his stuff when it comes to Silverados and the T1 series.
Found out if you are super low on gas, you get a "LOW" on the DIC - was showing about 30 miles to go, and then this popped up....   squeezed 23 Gallons in.....
YUP! its all based on that automatic average MPG....mine popped up as i was coming back into town after a road trip....said low for about 5-10 miles. I stopped and filled up and still had roughly 2+ gal left in the tank.
Good heavens, man. Gas is $2.16 here in TX. That's $34 less per fill up for me than you. ?
We're paying on average right now about $4.50 a gallon here in winnipeg and that is low right now.  Back in the summer we were paying between 5 and 6 a gallon.
  • Sad 1
All I can say is I'm glad to be in Alberta.
California sucks ....
First time poster, long time lurker. Found one a while back and not sure if it's been posted yet. Actually the kids get credit, they found hidden compartments in the back seat on my 2019.
  • Confused 1
if you're paying $2.16 for gas you're pumping the cheap low 87 octane gas, 93 octane is averaging $2.70 gal
as much as I'd like to pump the lesser priced gas the 6.2 loves 93 octane, I figure the cost is justified in better performance and increase in MPG
Yep, you need it for that, the 5.3 will run on anything
On 9/1/2019 at 5:37 PM, Cpl_Punishment said:
Would you say they're good enough not to bother getting towing mirrors when I get a 2020? I'll probably pull a ~24 ft travel trailer a handful of times a year.
A little late on this one , but I had a 2017 LTZ Z71 2500hd with the tow mirrors and really liked them, my 2019 1500 LTZ Z71 with tow package mirrors work just fine. I recently towed my travel trailer 4000 miles without any issues. There were a couple of times that I wished I had the bigger mirrors but managed just fine.
Found out today while furiously scrolling through contacts that if you scroll the wheel really fast it pops up a menu to scroll by letter! Pretty neat especially as I heavily rely on my phone in my truck for work! Now if the engine light would stop coming on....
While investigating an attachment point for my light bar I found these fins/vanes in front of the radiator. They look like they rotate and all connected by a rod that is most likely controlled by a servo. My guess is that they're there to restrict airflow in super cold temperatures to allow the engine to run at optimal temp.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
