Mayor Posted May 22, 2019 Posted May 22, 2019 7 minutes ago, Mayor said: May 6 2019 dropped off my 2019 Denali for rear windshield leak. They tried to pull and reseal, still leaked. Ordered new rear windshield and it came in Friday May 10th. Glassman supposed to install Monday afternoon May 12th. It's Wednesday afternoon and truck still isnt ready. Hoping for some good news tomorrow. It's been 16 days without my truck!??
TB3546 Posted May 22, 2019 Posted May 22, 2019 10 minutes ago, Mayor said: May 6 2019 dropped off my 2019 Denali for rear windshield leak. They tried to pull and reseal, still leaked. Ordered new rear windshield and it came in Friday May 10th. Glassman supposed to install Monday afternoon May 12th. It's Wednesday afternoon and truck still isnt ready. Hoping for some good news tomorrow. It's been 16 days without my truck!?? Hope it's resolved for you. I waited 16 days total and mine got the whole window replaced and that fixed it.
Mayor Posted May 22, 2019 Posted May 22, 2019 1 minute ago, Ktapper said: Hope it's resolved for you. I waited 16 days total and mine got the whole window replaced and that fixed it. I hope so too. This is unbelievable!
TB3546 Posted May 22, 2019 Posted May 22, 2019 3 minutes ago, Mayor said: I hope so too. This is unbelievable! That's exactly how bad mine was. I had both sides too.
sdkraemer Posted May 22, 2019 Posted May 22, 2019 May 6 2019 dropped off my 2019 Denali for rear windshield leak. They tried to pull and reseal, still leaked. Ordered new rear windshield and it came in Friday May 10th. Glassman supposed to install Monday afternoon May 12th. It's Wednesday afternoon and truck still isnt ready. Hoping for some good news tomorrow. It's been 16 days without my truck![emoji58][emoji58]Do you happen to know your build date?Sent from my ONEPLUS A6003 using Tapatalk
Mayor Posted May 22, 2019 Posted May 22, 2019 49 minutes ago, sdkraemer said: Do you happen to know your build date? Sent from my ONEPLUS A6003 using Tapatalk 09-2018 1
econometrics Posted May 22, 2019 Posted May 22, 2019 Bingo. For those readers new to this thread, the rear window leak issue has almost exclusively been on trucks built on or before 10/2018. 1
At4Rotation Posted May 25, 2019 Posted May 25, 2019 So what has been the fix for those who’ve had theirs repaired? I took mine in on Wednesday and they ordered a new silicone recommended by GM per a bulletin that was sent out on this issue. Unfortunately, the new silicone did not correct the issue.
white94rx Posted May 25, 2019 Posted May 25, 2019 First step is to remove the rear spoiler and apply the sealant/caulk. Second step, I believe, is a complete new rear window unit.Sent from my Pixel XL using Tapatalk
fish_guru Posted May 25, 2019 Posted May 25, 2019 A new rear window is the definitive solution. Those windows are straight up defective and should be replaced. Adding extra sealant to a defective window is treating the symptom, not the cause IMHO. Unfortunately your dealer is likely to follow GM's TSB so just sit back, play the game and drive the loaner like you stole it. But hey, what do I know...only took them three tries to fix mine...the third time being with a new window.
KevinTM Posted May 25, 2019 Posted May 25, 2019 Picked mine up Tuesday. 3rd time was the charm. It’s rained a little here and there since I picked it up and it looks like the issue has been resolved. 26 days total in the shop. GM is also paying my care note for one month.
ShamrockShooter Posted June 4, 2019 Posted June 4, 2019 Supposedly there is a May 30th update to bulletin 18-NA-383 for the rear window leak repair. Does anyone have access to it to see what changed from previous versions?Sent from my Pixel 2 using Tapatalk
Sierra Dan Posted June 4, 2019 Posted June 4, 2019 On 5/25/2019 at 1:28 PM, fish_guru said: A new rear window is the definitive solution. Those windows are straight up defective and should be replaced. Adding extra sealant to a defective window is treating the symptom, not the cause IMHO. Unfortunately your dealer is likely to follow GM's TSB so just sit back, play the game and drive the loaner like you stole it. But hey, what do I know...only took them three tries to fix mine...the third time being with a new window. If only this were as easy as wishing GM would replace the known defective A/C Condensers and Vacuum Pumps on our earlier K2's. They would rather have two or 3 techs spend a day or more with tubes of silicone to repair rather than install a new rear window.
ShamrockShooter Posted June 4, 2019 Posted June 4, 2019 If only this were as easy as wishing GM would replace the known defective A/C Condensers and Vacuum Pumps on our earlier K2's. They would rather have two or 3 techs spend a day or more with tubes of silicone to repair rather than install a new rear window.That is why I am curious what the new tsb says. Maybe they changed it to say replace window.Sent from my Pixel 2 using Tapatalk
