7 minutes ago, lebag335 said:
Yeah, I figure as much. But, they said they have to try this patch first before replacing.
Yeah they have a certain procedure to follow.
1 hour ago, lebag335 said:
It’s at the dealer now. I’ll know how it turns out by this afternoon. Fingers crossed!
I'm going on 3 months with mine being resealed. Been through touchless car wash a few times, and many hand washes, and I shoot jet of water into all the cracks around the 3rd brake light every time I wash it...So far no more leaking.
Wow! I want to use your dealer!
I seriously considered just breaking the window and having it replaced through insurance at a reputable body shop. It’s a damn shame to have to consider those kind of options.
Same for me, until it leaked last week.
  • Sad 1
Mine leaks worse than ever before after they sealed it again.. I also find that if I look at my front bumper too hard the paint chips.... Thinnest layer of paint I have ever seen
  • Sad 1
My front bumper is chipped so bad that i'm going to need to get it painted, not looking forward to that bill, so pissed at myself for not getting Xpel put on it before I started driving it.
Mine made it 3 months, thought for sure it was good to go, then it started leaking again. If gm isn't going to replace window I'm going lemon law or possibly file an insurance claim and have my rear window replaced, then buy an F150. I couldn't in good conscience trade this truck in unless the rear window was replaced first.
Don't the F-150s also have issues with the rear windows leaking?
ford,dodge, and chevy/gmc all of them have water issues with the rear window right now
Have you not brought that up to your dealer?  This was an issue on the K2XX trucks with painted bumpers & they allowed for a one time repaint.  After that one repaint, you were on your own.
Thanks, I will when I take it back in for the window leak.
Best of luck - and if it swings in your favor, get that PPF on there. ?
Well, I didn’t get my truck back today. Dealer said the sealant was slow to set up. Apparently I’m the first one my dealer has done. That doesn’t give me a warm and fuzzy feeling. Hoping for better news tomorrow.
Add me to the list of those affected by rear window leaking.  Bought the truck on Wednesday with 86 miles on it, had water on both rear seats on Thursday.  It's an 8/18 Fort Wayne assembly LTZ.  Dealership can't even look at it till a week from Tuesday 9/3/19.  Needless to say not happy one bit.  I hope they are able to just replace the window, without trying the sloppy caulking job 1st, but I doubt it.
You’re going to need a new headliner as well, that requires the removal of the windshield.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
