Hey everyone, Just saw this thread and went to look at my window and I'm also a winner of the leaky rear window! Anyone who live in Socal have a dealer they taken it to that have knowledge of fixing this problem? I have a 2021 GMC Sierra and I can't believe that this been going on for 2yr and GM haven't addressed this problem.
Tustin knows of the issues and goes through the steps one by one.
Hardin said they never heard of leaking windows
I use Courtesy Chevrolet in San Diego. Katrina is my service writer. She's familiar with the leaking rear window problem. They have handled several of them already.
Were they able to fix it correctly?  Or you had to go back several time?
I live close to Long Beach GMC I'll take it there and see if they can correct right the first time but I was hoping someone on here had good experience with a dealer already.
I haven't had a leaky window, yet. Every time my truck has gone in for service (accessory install, 7500 mile service) I've asked them to check for a leaking rear window. Nothing so far. I also check after my carwash every 2 weeks, and after rainstorms (like today's) and I don't have this problem yet. With that said, I'm satisfied with the type of service I received from Katrina. When a 2 hour install job ended up taking almost a week she kept me in the loop and even provided a loaner. Really good customer service so far.
You're almost 2 hours from me. I doubt you'd want to travel all the way down to San Diego when you have a dozen other dealerships that are closer.
Did you know what they did to your truck to stop the leak? Remove and replace the window or just reseal?
Never knew about this issue when I purchased my 2020 Silverado......
I kind of wanted a sliding rear window when purchasing but my pick of the lot RST did not have it included.
Seeing this, I'm pretty happy I purchased one with the solid window.
23 hours ago, f8l vnm said:
Me :(
They fixed mine like 4 months ago but just started leaking again this morning . Rain pretty hard overnight and this morning i got into my truck and saw the leaking window. So pissed right now . One time i can understand but now a second time ? How incompetent of GM
I am in your area.  What dealership did you use for the repair?
Dropped of this morning for round 2 at Tustin GMC. Service tech said that this time they will replace frame and he think that also includes the glass. This will be done by a 3rd party glass company. Hopefully this does the trick. Bummed that I will need to get my rear glass tinted again. Going to try and get GMC to cover the cost or at least float me some GM point instead. Got me an Acadia SLE as my loaner this time.
Did you not have factory tinted rear windows? Or did you just want it darker. I would think if you didn't have factory tinted you could get them to put one in.
Sent from my SM-A505U using Tapatalk
I had all my windows IR Ceramic tinted after I bought the truck. If they replace the back glass, I will have to get it tinted again out of pocket for me unless I can get GM to cover the cost.
Just got my truck back. They replaced the entire rear window. Tech found 12 inches of sealant not applied from the factory. How I didn’t have a rainforest waterfall I have no idea. Supposed to rain tomorrow. I’m gonna park it in the driveway and see what happens.
Again, I haven't had a leaky window, yet. I'll let you know what happens when my turn comes around.
Rydell in Northridge.  Going to try GMC in Thousand Oaks now
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
