Just talked with the "new" dealership dealing with my truck after the last dealership nightmare of two tries.... last night I texted him that I would like the TSB performed regardless of what his glass guy finds that is causing my leak. I told the previous dealership that TWICE because it was already taken apart so they might as well do it. The first time they replaced the entire thing, didn't do the TSB... the second time they "resealed" it, didn't do the TSB... this new dealership texts me back today and said they already performed the TSB and sent me a pic of the sealant on the top AND said that the window wasn't causing the leak but that the clips holding that stupid spoiler was where it was coming in. He sent me a pic of the old style yellow plastic clip and said they changed styles... all GMC did was add a gasket... and sent me a pic of the new clips they were installing. When I get my truck back I will wait a bit and see if it leaks... if it doesn't then I will add the tube gasket I mentioned in a previous post here to the spoiler gap on top and to the gap between the spoiler and the window frame. HOPEFULLY, I will finally be done with this....
Was you headliner getting wet every time it leaked?  Mine drips off the rails, but the headliner seems to be dry.  I may give the dealer a call and at least discuss it with the Service Advisor.
No, my third time the drips were pretty minor and just dripped on the top of the seat....
Got my truck back this morning.  They originally started with taking the spoiler off and applying the sealant.  They confirmed this didn't fix the leak and kept the truck longer for a replacement window.  So far so good, no leaks but its only Day 1.
Has anyone explored installation of this aftermarket Power Slider sold on eBay?  I contacted the seller and they claim it fits the new 2019+ body style.  The design is interesting as it looks like the plastic slider track is mounted lower, allowing for glass to body contact around the entire sealing perimeter of the window.  Rather than trying to sandwich the plastic slider track (known to crack) between the glass and body like the OEM GM design does.
As I have said before the aftermarket will fix this. They see money to be made. Now several companies will compete for the best fix. I hope mine holds up until there are several choices. Then I will just pay to fix it right.
Sent from my SM-T510 using Tapatalk
On 12/9/2020 at 5:14 PM, Dali555 said:
Got my truck back after a week and a half. I’ll have to take a better look tomorrow as it was dark when I picked it up. I’ve attached a pic of the new glass numbers as well as the top of the frame and a pic of the old frame... slight difference
I've had my 2019 now for just over a year and took it in last week for the third time with this issue.  The first two times they resealed it and called it good.  I told them this time I wanted the window replaced, and I now have this same version.  The tech notes say "The rear glass separating from frame".  I didn't get to see the old window so I can't verify exactly what it looked like but if this is accurate then it appears there may be another issue other than just the cracked frames and failing sealant.
The plastic frame is glued to the window so even if the top is sealed real good eventually the frame will separate from the window elsewhere. Solid window is the best way to go to avoid future issues.
On 12/31/2020 at 11:41 AM, SamDSJR said:
LOL. A 2020 or 2021 2500 Silverado. With any luck I'll be able to lemon that one too (they are still leaking and still documented cases on 2500's with build dates as late as 9/20.)
My 2020 2500 built 8/19 is also leaking. Just noticed it over the weekend. Small drips in the upper corners of each side, then dripping on the top corners of the back seats, also has stained the corners of the headliner.
Has anyone filed a formal complaint with the NHTSA? I have pasted the link to the form below and also NHTSA's website where the form can be found.  Their website lays out how complaints are handled and used to determine if a recall is necessary.  I feel like if we get enough people to file a complaint, they will investigate the problem.  It is a possible step to having a recall issued.  The fact that so many people found this thread and then went check their trucks, tells me that there are probably a large amount of people that don't even know they have a leak until it gets bad enough to start smelling of mold and mildew. Mold inhalation/toxicity is a serious health issue, but in most cases is overlooked and misdiagnosed. If enough cases are approached from this safety standpoint it should create enough attention to have a recall issued.  Thinking ahead not only for ongoing issues for the new trucks, but as these 2019s are traded in and bought by more unsuspecting consumers who may be out of bumper to bumper warranties and who will be affected by this ongoing issue.
Lets spread the word and get as many complaints filed as possible.
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
https://www.nhtsa.gov/recalls
Sorry if this has been brought up already.  New to the leak club.
How many of you have or are in the lemon law process? If so what have been your outcomes? Good and bad. Thanks!
We have had a lot of rain here lately. Everything from down pours that are causing flooding to light rain. I keep checking but still not leaking. Although yesterday and today I will be driving the old truck. We had a massive wind storm night before last and there is stuff all over the roads. I don't want to risk scratching the black paint so it will stay in the garage.
Hi - I am writer for the Detroit Free Press and I see a lot of complaints about rear windows for Chevy and GMC pickups. Would anyone be willing to talk to me? [email protected].
Another update.  Its been a few weeks.  Lots of rain here in the Northwest and still no leak after the window was replaced.  I took it to the self car wash(it needed it).  Soaked the top and got it all shiny again.  I didn't find a drop inside.  I hope it stays that way :)
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,129 Guests (See full list)
    • Your tire pressure issue may just be batteries, you can reset them using tge Ing switch (I think) and the owner's  manual. ChatGTP will b e a faster, better help than Google.
    • The thinking is that starting out in a higher gear makes it easier to avoid applying excessive torque when pressing the gas pedal. In a modern 4wd truck with 4 low and a limited slip or locking rear end, I would use 4 low and try to crawl up the ramp. Sometimes if they are too slippery, you have to back up to let the boat have some bouyancy, and then accelerate briskly to get some momentum to help you pull the through the slippery parts.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
