I recently purchased an AT4 withe the 6.2L.  I love most everything about it, but I'm considering adding the GM produced/installed cold air intake and cat-back exhaust.  All I'm looking for is a little more rumble, not trying to announce to the world I'm driving by or wake the neighbors when ever I pull in.  There's very little in terms of reviews or vids out there to give me some insight.  What do you guys think, Is the dealer's performance upgrade offering on the "tame" end of intake/exhaust mod offerings?  Will it be an annoyance inside the cabin while driving down the highway?  I know these are pretty subjective questions, and thank you in advance for any insight you can offer.
The exhaust isn’t obnoxious at all but certainly a noticeable difference over the stock exhaust which is basically silent at all engine speeds.
If I’m honest, it was a little louder than I expected for a “factory” part and it took a little getting used to. Overall, I have no complaints there because it calms down VERY nicely at cruising speeds. There is no drone at all and sounds pretty much the same as it did before on the highway. Stop and go, in-town type driving you do hear some more rumble in the cab, but it’s not to the point of having to speak up or anything.
Cold starts are on the loud side until the idle drops but that’s the only time I hear it from in my house.
I think it’s a very nicely designed kit and I’m very happy with it. The performance boost is a great plus, as it’s good for 13hp on the 6.2.
Videos are very tough to judge how it sounds. I am going to make more shortly but for now I just have the two vids below. Obviously a Chevy, but the same exhaust part # and engine you have.
I did both and am happy with the outcome. Much better sound and the truck just feels a bit more lively.
I installed both on my Denali with the 6.2. It was a little loud for me so I added resonators just prior to the tips and that toned it down a bit. I wanted to know it was a 6.2 but did not want it too be obnoxious
Would it make any sense to only add the cold air intake, or only the exhaust?  As I type it it feels like a dumb question, if I increase the air in I'll probably need to increase the trucks ability to expel it, but I know practically nothing about exhaust systems.
You can att the CAI by it's self but to get the most benefit the exhaust is also needed.
I just had the performance exhaust placed on my 6.2 AT4 yesterday. Love it. Did not do CAI. I just couldn’t find anything that definitively said it was worth the money. I’m not opposed to doing it (or maybe one of the other aftermarkets) in the future if it will improve performance/ mpg’s. The exhaust itself did everything I wanted it to for the sound.
Same here. The exhaust is good for 13hp according to GM. No numbers for the CAI alone, but GMC reports that the CAI AND exhaust add 15hp in the AT4 performance package. That would leave 2hp to be attributed to the intake.
Yeah, a lot of my decision was based on your posts, lol. So, if anyone else is curious, I have found OnTheReal’s info to be quite accurate and reliable. ??
Thanks! I don’t mean to repeat myself about it, but the same questions keep popping up about their CAI. GM could squash it by posting the numbers themselves, but I suspect they don’t for a reason...:rolleyes:
anyone got the part number handy I have a 6.2 hicountry gonna try just the exhaust thanks
Save yourself the money on the GM Cat Back System. The restriction is the flapper valves. Each one has a 1.25" restriction when wide open. I have posted the picture of the flapper valve many times on this site. I will post one more time. I cut both off and installed a Magnaflow 12909 and left the resonators because they do not restrict the flow. The entire cost was less than $200 including the labor at the exhaust shop.  here is the muffler on  Amazon  https://www.amazon.com/gp/product/B000XQM1LC/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The Magnaflow is a straight through muffler, You can hear it on the freeway but after about 400 miles it quiets down.
Any drone? How much louder did it get?
    • First time it really happened to me was when I was 69 yrs old and I was called "Old Timer" by a complete stranger. Then in rapid succession came the aforementioned "Old Man" and my favorite of all "Pops".
    • Yea that's pretty normal to be off a few degrees.  Usually 2-4 degrees from say a weather app or thermometer.
    • I just replaced the ambient air temperature sensor.  Easy as pie. I simply had to remove about 10-12 clips on the plastic cover over the radiator and remove two T-10 torx screws on the hood release lever to liberate the cover (Amazingly, none of the clips broke.  All came out and went back in with zero problems). Once the cover was removed, the temp sensor is easily accessible. The sensor cable snakes through a few guides and can be pulled out for even easier access to the sensor. I was able to work the sensor out of the mounting hole.  There is a red sliding catch on the plug that must be pulled back to disconnect the cable.  The plug was quite tight.  I had to use a screwdriver to pry it out. I plugged in the new sensor ($6.45 from RockAuto), snapped it into the mounting hole and re-snaked the cable. I put the radiator cover back on and reattached the lever arm to the hood release.  All done!     I started up my Suburban.  The temperature read 82 °F. Other thermometers at my house read 80 °F.  Close enough.  It might be reading high as my vehicle was sitting in the sun.
    • Remember when you were 50 and they called you Old Man?
    • That one looks decent for the price   BUT..I want something that also supports OBDI/1.5. A lot of the prosumer-grade scanners don't have legacy support in order to keep costs low. I believe the Autel does if you go higher end with them.   For fun, I reached out to a local Snap-On rep because I was interested in the 2600. $1895 MSRP, says he can do $1595. That's still a lot, but then again, that's not a horrible discount for just asking out of the blue. Could probably do better if I was a regular buying off his truck, but I'm not.   Not sure if I mentioned but I didn't realize with USED scanners from Snap On that you need to make sure a) the serial number isn't flagged as stolen. On the newer ones, SnapOn can remotely disable the device if it's flagged in their system. And, customer service can tell you if it is, if you're thinking about buying used. B) Make sure it's paid off. If the seller still owes money to the truck or if they financed through Snap On, the device can be remotely disabled until the balance is paid. It's less clear if SnapOn will tell you if a balance is still owed; I didn't make it that far with the used model I was considering. I did read that SnapOn has no way of tracking any "truck financing" deals between the SnapOn rep and buyer, only if they financed through corporate. So there's that extra caution needed.   Still waffling on whether I go with a ~$500ish Autel/TopDon or spend bigger money. The value seems to be in the prosumer brands. I'm not giving them enough credit TBH, actual production repair shops use them daily BUT I'm still allergic to certain kinds of underdog products trying to unseat American companies with solid reputations. SnapOn's scanner isn't wholly made in the US, but it is assembled here and they have US support and probably the most proven/ robust legacy support.   Something to think about. Value, or principles? There's a $1k difference.
