25 minutes ago, CTB said:
95% of the time spent in whatever truck I buy, will be commuting. 60/40 highway/city. 22 miles one way. 5% of the time I’ll be pulling a camper that weighs just under 4000lb loaded. Considering the previous, purchase price is one of the biggest factors going into my decision. My only concerns are; how relatively new this engine is and how many problems the 8 speed has had over the years. I plan on driving this truck for at least 10 years.
I go back and forth daily between ordering a custom trail boss with the 6.2/10spd and finding an rst with the 2.7. If the 2.7 came with the 10 spd I wouldn’t be nearly as reluctant.
yeah its perfect for a lot of people, I just don't understand why it was stock motor is all
2.7 Turbo power is a weeee bit greater than the Ecotec3 4.3 on E85. 5 hp. and a few pounds/feet more torque. The 2.7 comes with the lower geared 8 speed. The T1 has a new frame that is suppose to be all that and a bag of chips. Yet when I look at the tow and payload ratings the 4.3 on 87 octane still out pulls and out hauls the 2.7 buy a few hundred pounds in both. In theory the motor claims a bit more city mileage and about the same highway numbers. In practice ????? Doing less with more?
Other that the fact that you can get the 2.7 in nicer trim levels I'm confused as the point of this motor.
Educate me.
Educate me.
I can't answer your question, but could it be that the turbo 4 outweighs the V6 with its turbos and intercooler taking away a couple hundred pounds of payload? Seems odd to offer both of these engines being so close statistically. Seems very odd you can spec the V6 to move more with the 6L trans vs the 4cyl with the 8L trans.
Educate me.
2.7 has better driveability because the 4.3 takes over double the RPMs to make its torque. Much of the US outside of the Midwest doesn’t have easy accessibility to E85, so it’s kind of silly to use the numbers like your average every day driver is pumping that.
My guess is the limitation on towing comes from maxing out the intercooler, where as a 4.3L doesn’t need one. In the real world, there won’t be any difference in the use case for either engine.
I personally believe that the 4.3L will be phased out for a gen 2 2.7 eventually. They don’t make much sense in the stable together. I do think GM made a mistake going for 4 big cylinders instead of 6 smaller ones on the design. I think a 2.7 6 banger would have delivered better MPG. Either way, having driven both quite a bit now, I wouldn’t take a 4.3.
Educate me.
The turbo offers more usable torque at low revs.  Most apparent when climbing a mtn pass.  NA engines struggle or have to turn high revs whereas the turbo just tractors up in top gear.
So the V-6 has the capability to get great fuel mileage with cylinder deactivation to make it a 4 cylinder. The 4 cylinder has a turbo to have the the power of a V-6. There’re playing with us. A few years ago you could get an E-85 capable 5.3 and get close to the 6.2 in power. Now they can go all the way down to one cylinder. I’ll keep watching till they figure it out. It is entertaining though.
In top gear? Up a mountain pass? At full rated towing weight? Really? I suppose at the speed limit too?
Oh I have got to see the video on that run!
Where can I find it? Got a link?
  • Confused 1
Not that I am going to engage you on this again, but let's see a 4.3 do what you are stating above. It can't, no engine can. Now, review the video above to see it operating as designed... which if you were to run neck and neck with your beloved 4.3 you would see it get its ass handed to it...
12% more torque and a broader, flatter torque curve where it matters...
It makes sense that the new kid on the block actually took my request seriously an did not assume I was looking for a fight.
I thank you CTB (whoever you are). I was given the information I asked for without all the forum drama. Excited I looked that site over for a test of the 4.3 Ecotec3 and found none. I'm not devoid of common sense however and have no illusions that the 4.3 will do the IKE in 8 minutes flat. I've climbed that hill hundreds of times with NA motors.
All that said and as impressive as the video is it did not 'tractor' up the IKE in high gear. It spun 6 K and finally pulled down to 4.8 K or so and it didn't do it in high gear as claimed.  By the hype I was expecting a speed limit assault at 2500 rpm in high gear.  Thus my amazement. It was truly that simple.
I didn't say anything about towing, that is your thing.  I want my truck to do my thing which is 70mph+ up WA state passes with my family in the cab and my bike in the bed and getting good city mpg for commuting to work.  And my truck does my thing great.
I don’t believe any engine 6-8-10 speed combo is going to stay in its highest gear lugging up a hill. The whole point of the exercise is to use the highest gear possible in its TQ range. While keeping the RPMs as low as possible using the least fuel at the desired speed. Lugging like a tractor wouldn’t accomplish that. Even with no load. Driving awhile with stick would teach a person that.
Bingo!
I realize I'm wasting my breath but for the silent thread watchers these charts show why my 2 7T truck tractors up Steven's pass.
The 4.3 V6 is the bottom curve but it's the same for most NA powerplants that make max torque up at high rpms. The 2.7T is at max torque at 1500 rpm.  As I am not accelerating or dragging a 6k pound trailer my truck never shifts as the grade increases it just adds fuels to produce more torque at the same rpm.
Turbo engines can be setup for torque or top end hit.  As MDSilverado has said multiple times GM went for torque.  The engine runs out of breath well before the rev limiter but it doesnt matter because it doesnt need to turn 4k to make enough torque to maintain 70mph up a grade and that's why its awesome.  I think the differences are magnified at partial throttle settings where we all operate 99% of the time.
The concept is probably foreign if you haven't driven a small diesel or other forced induction engine tuned for torque which is why there are so many doubters and haters.  But Im tired of people coming to our thread asking for explanations and then telling us we dont know what we're talking about.
Drive the truck and decide for yourself.  I think most will love it.
This is my 3rd turbo vehicle and I'll never go back.
Edited by zzrsouth
  • Like 4
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
