On 10/6/2019 at 7:47 PM, hramales said:
How the ride quality on that set up, I’m looking at doing something similar on my 2wd RST. Also do the tires stick out any on the sides? Any rubbing issues?.. Sorry for the bombardment of questions but I’m new to the truck scene. Thanks
It's all good.  No issues.  Rides like factory.  No rubbing.  Tires do not stick out.
On 10/7/2019 at 7:48 AM, tannerm24 said:
Motofab 1.5” level.
35/11.50r20 Ridge Grapplers.
No offset. No trimming. No rub.
Make sure to measure your rake. I had the 1.5” level installed and it’s perfectly level. 2” would have been too much.
Thanks for posting, good to know. That’s just very slightly smaller than a 295/65r20, so that should fit well too. I have 2” both front and back, so kept the rake.
Can you post a pic like this but from the rear so I can see tire width from that angle please?
Learning a lot in this thread, looks like a 2 inch level on my ltz 2wd will give plenty of room to put 33's on the stock 18's. Quick question though, is there one leveling kit that's better than the other when comparing a top spacer or bottom spacer? Thanks.
You can fit 33's without a leveling kit with plenty of room.  The stock wheels that came on my truck were 275 60 20 which is a 33.  With the leveling kit you can go with a wider 33 or taller than 33. I have the 2 inch Rough Country level which is a bottom spacer with 295 60 20 Nitto Terra Grappler G2 and it rides nice.  I don't know if a top or bottom spacer is supposed to be better but so far I like the bottom spacer on my truck.
I called several level kit companies.  Some claim top vs bottom doesnt matter.  Others say top is better as it is more robust I'd u did actually go offroad
Sorry to ask what may be for some of you the DUMBEST question of all time, but . . . what are all of you meaning when you say the term "rake"?
Just trying to learn the vocabulary.
    KJEK
    KJEK
  • Who's Online   6 Members, 0 Anonymous, 603 Guests (See full list)
