On 8/16/2019 at 6:48 PM, 17Allterrainx said:
Installed the AT4 Rough Country 2” leveling kit. These are the after results!
How do you like the Rough Country kit I was thinking about going with it for my RST
2.5" level kit and 1" wheel spacer up front.
Rear left stock.
OEM LT rims with 35x12.5's
Look great! Any rubbing issues with the 35s? Did you use the spacers for clearance issues or just for looks?
Sent from my ONEPLUS A6013 using Tapatalk
For the price you can’t beat it. I haven’t had any issues but I have noticed a slight humming coming from the front wheels at like 90+ mph. Idk if its the wind hitting it or what. Haven’t really looked into it.
If anyone is interested I have  a brand new Suspension Maxx leveling kit for the 2019 denali 1500. It is a 2.5 in front and 1.5 in back. I have the full kit still in box Im just deciding against putting it on because I do not think it will fit in my garage if I install it. If anyone is interested let me know.
Rubbing? Oh yeah! The spacers were needed for clearance at the upper control arm. Could've got by with 1/2" but I wanted the front out a little bit. Along with that and the front only lift/level, I was shooting for a stance similar to the baja trucks. Without the mudflap mod, I still had only 22-23° of turn availible till I could hear rubbing. After removing the rear fender mounting bracket and pulling the inside of the mudflap to the frame rail, I get 35ish° which is almost full lock.
2” Motofab up front. 2” Motofab blocks on rear.
(I like a little rake)
Cooper Discoverer ATP 275/60R20
Edited by Method2Madness
  • Like 4
On 11/21/2019 at 2:01 AM, 17Allterrainx said:
Replaced the OEM Bridgestone Duelers for 35” Nitto Ridge Grapplers. 2” RC AT4 leveling kit. Zero rub.
Are those 11.50’s or 12.50’s?
Went back out and took a pic in nearly the same spot as I took the before pic.
(2” leveling up front, 2” block in rear)
  • Like 4
On 11/4/2019 at 11:03 AM, Silver2019 said:
Please do!
On 11/7/2019 at 9:10 PM, econometrics said:
Yeah! More pics, please! I have the exact same truck and have been wondering what it would look like with a 1.5” and 285 or 295 tires!
Can you post some additional pictures? Id be doing a similar setup.
How does the ride and handle compare to the OEM duelers? I have an older Tahoe that rides like crap since I added 10 ply tires...wanna avoid that mistake with my new truck...
On 11/7/2019 at 9:13 PM, Chance1025 said:
This is my Trailboss, with the black parts deleted, and a 1.5” level on 285/65r20 KO2’s. Love the ride. Feels like stock.
Dang, that looks nice. Did you notice a big drop in power with the heavier tires? How about ride quality and handling? I want the exact same look on my 5.3 LTZ. I wanna go with the same tires as you or the 35x11.5x20 ridge grapplers. Thanks!
Thanks man! I have always loved these BFGs. I got the 285’s and honestly they do look a hair small. They are a tall tire, but just a tad skinny in my opinion. I did that on purpose though, because they offer a little less weight (drag) and better fuel economy than the 35x12.50’s in the same tire. Power loss is negligible. Ride is close to stock, but with the 10plys and the leveling kit it’s a bit stiffer. I’m running them at 35psi cold, which has helped some. Handling is nearly the same. A touch more body roll, but that’s bc the center of gravity is higher, and I kinda like that fee anyway.
I have had BFGs on my last three trucks, and know how great a tire they are. But I LOVE the way the Nitto Ridge’s look. If they weren’t so heavy I prob would have bought the Ridge Grapplers in 35x12.50’s.
Edited by Chance1025
I’ve had two sets of Nitto Ridge Grapplers, both had their siping wear very fast and started slipping with almost 15k - 16k miles on them, you’d be better off with KO2’s.
KO2’s have siping that runs straight through the lugs
The Nitto Ridge Grapplers siping reminds me of an after thought and wear quickly
New
With 16k miles on them, siping wearing prematurely creating slippery nerve racking moments.
There was a study done by a marketing firm some years back, people prefer the chunky sidewall and that’s why Nitto Ridge Grapplers became such a big hit but it’s a phase, stick with experience and you’ll be fine.
Sent from Above
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 779 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
