Setting of Lo, blower all the way up, seems to take forever to cool off the truck. Even after airing it out. I’m only in Wisconsin too, what about people in truly warm states?
My Tacoma would get so cold you could see your breath.
You have to share the A/C with the people in the back seat now. :D
  • Thanks 1
  • Haha 3
^ He isn't wrong. Since trucks don't have a separate rear system like the SUV's it takes away some of the power and efficiency from the front vents to power the inefficient rear vents. That is why all the complaints on not having rear vents and people being "hot" back there was comical with the K2's. The air coming out the back is warmer and moving much slower than what is shot out of the front vents. I have no doubt unless they made some significant changes to the system that the K2's are better at cooling the cab and rear passengers than the T1's. Every truck I have been in the rear vents were trickling out air that made my knee feel good, that was it. Being in Texas my truck cools off well and the rear passengers are fine, tons of cold air is coming out of the four front vents.
Is there a way to close the rear vents?
Tyler
Edited by amxguy1970
No problems with mine. We get mid to upper 90s with a lot of humidity 80-90% all summer. You have to remember you came from a small truck to a full size and it takes some time to get the heat out of the seats and interior.
I'd have it checked if I were you. I'm in hot humid La. and my A/C is cold. I have an A/C thermometer clipped in the vent and it gets to 38°.
I might go have it checked. It certainly shouldn’t take 20 minutes to get down to 70 when it’s 85 out.
I've noticed that when the AC temp is at "low", it's really only cool and not ice cold like my previous GMC trucks.  I have to have it on "re-circulating" for the air coming out to be nice and cold.
I'm in NC where it gets hot and humid. I have no complaints about the A/C in my 19. I also remote start my truck 99% of the time, so it's already nice and cool by the time I hop in.
Is there still the option to adjust max blower speed as there was in the k2 trucks?
Edited by DeePa
My 2015 Yukon cooled much faster than my Trail Boss. I never had to turn the fan speed up past half way even on the hottest days here in Florida. I regularly turn the fan speed to the fastest setting in my Trail Boss.
The Yukon has a separate evaporator and controls for the rear seats and the Silverado does not.
Not so.  The amount of air that comes out of both my front vents and the ones in the rear is very adequate and cold. Much improved over my 15
Mine is currently in the shop with an Evaporator leak that has rendered the system ineffective. And yes, the evaporator requires the dash to be removed! I have 2,300 miles and I'm already pissed off that I went with the Silverado.
  • Sad 1
It's 92 here in Ohio today and I'm ice cold.  Must be a leak in your system, op.
The high fan speed helps move air around better but the air is not as cold with the blower on high as the air is rushing through the evaporator too fast. The lower the fan speed the colder the air will be out of the vents. Don't turn the recirculate on if your truck has been sitting in the hot sun all day because on recirculate it's sucking the 120° interior temp through the system taking it that much longer to cool down. With recirculate off the system is sucking the outside air instead of the hot cabin air. Once the interior cools down, then turn the recirculate on. It'll stay cold and run more efficient because the cabin air is cool and is recirculating.
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
