1” motofab lift
fuel vandal 20x9 +1
Ridge Grappler 305/55R20
Bracket mod behind mud flap, no rub.
ok, i have to know. You're on a sandy loam dirt road and there's not a spec of dirt even on the surface tread of your tires??????
Edited by Okievision
  • Haha 1
Haha, too funny!  So I washed the truck, then drove it about 1/2 mile down this dirt road and took some pics, then drove back home ?.  It’s basically hard dirt, it leads to a state forest near me.
  • Haha 1
17" Method MR 312s. 35/12.5/17 KO2s, Baja Kits Chase Kit Suspension (Front King coilovers w/remote reservoirs, boxed upper control arms, rear Kings w/remotes, 1" lift rear) . No rubbing.
Edited by foxcoupefan
  • Like 5
Great looking truck. Do you have a link to this kit by chance?
What height are you running your coilovers? If max, do you have a diff drop? Sorry for the question parade... lol super interested in this setup.
Edited by jordanl010
Black Rhino Kelso 20x9 +12 offset
3mm hub centric spacers front only
305/55 BFG KO2
1.5” motofab level kit
No rubbing at full lock
  • Like 5
Looks great. Just curious.  When folks are going with 305s and aftermarket wheels, why not do a 20x10 wheel?  Wouldnt you need less backspacing then?  If seen several 305s on aftermarkets and they are all 9" wheels.
Edited by Ezekiel2517
305/55 BFG KO2
How big of spacer?
13 hours ago, brianc636 said:
How big of spacer?
3mm just a bit under 1/8”
GMC AT4 plus 2 in level
Tis 544bm 20x10-25
Open country RT 285x60x20= 33.6x11.46
Amp steps Denali front grill
Rubs bad......
Last picture is where I had to cut the metal. Next I will take out the support for the inner fender that holds the carpet.d3ff9f10471b6d9366ff0046db4e2324.jpg6026723fce81710e80cde4680357cc25.jpgd0609c0e2a58a8f58cba4ee1fa4c69f5.jpgb80dc0f48d4840a3204ef87faf508679.jpg88eaf1c977c18b11356882b825fc10c0.jpg
I chose 9” because I didn’t need any wider to fit 305s or if I decide to go up to 35x12.5 they’re still big enough.
I was trying to find the balance between wider tires/wheels and not having the tires/wheels protruding from the side of the truck.  Just want a cleaner look.
Thanks.  Seems like 10 may be overkill.  Lots of variations i see between folks rubbing or not.  Most of the rub seems to be on the mudflaps which would seem to be an outside rear tire edge rub.  This would lend itself to a tire that sticks out to far.  Gothp28 showed a -25 offset and bad rub. Most folks seems to be doing better here with almost no offset on 9" wheels. The folks with +1 seem to be okay.  But I know there are a lot more variables to consider
Oh yeah.
My baby has new feet and shoes.
Nitto Terra Grappler G2; 285/55R22
34" rolling size. Perfect fit on this lifted truck.
Slight rub on full lock. ab9e91ababb3a19cf78b62a5df8702d2.jpgd053ffe42fdb61dc4e9608fa7893f31c.jpg
  • Like 4
2 hours ago, Smoothbassman said:
Oh yeah.
Great tire and size, I’m very happy that I went with that same tire on mine as well.
    TopBo
    TopBo
  • Who's Online   4 Members, 0 Anonymous, 965 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
