1” motofab lift
fuel vandal 20x9 +1
Ridge Grappler 305/55R20
Bracket mod behind mud flap, no rub.
ok, i have to know. You're on a sandy loam dirt road and there's not a spec of dirt even on the surface tread of your tires??????
Edited by Okievision
  • Haha 1
Haha, too funny!  So I washed the truck, then drove it about 1/2 mile down this dirt road and took some pics, then drove back home ?.  It’s basically hard dirt, it leads to a state forest near me.
  • Haha 1
17" Method MR 312s. 35/12.5/17 KO2s, Baja Kits Chase Kit Suspension (Front King coilovers w/remote reservoirs, boxed upper control arms, rear Kings w/remotes, 1" lift rear) . No rubbing.
Edited by foxcoupefan
  • Like 5
Great looking truck. Do you have a link to this kit by chance?
What height are you running your coilovers? If max, do you have a diff drop? Sorry for the question parade... lol super interested in this setup.
Edited by jordanl010
Black Rhino Kelso 20x9 +12 offset
3mm hub centric spacers front only
305/55 BFG KO2
1.5” motofab level kit
No rubbing at full lock
  • Like 5
Looks great. Just curious.  When folks are going with 305s and aftermarket wheels, why not do a 20x10 wheel?  Wouldnt you need less backspacing then?  If seen several 305s on aftermarkets and they are all 9" wheels.
Edited by Ezekiel2517
305/55 BFG KO2
How big of spacer?
13 hours ago, brianc636 said:
How big of spacer?
3mm just a bit under 1/8”
GMC AT4 plus 2 in level
Tis 544bm 20x10-25
Open country RT 285x60x20= 33.6x11.46
Amp steps Denali front grill
Rubs bad......
Last picture is where I had to cut the metal. Next I will take out the support for the inner fender that holds the carpet.d3ff9f10471b6d9366ff0046db4e2324.jpg6026723fce81710e80cde4680357cc25.jpgd0609c0e2a58a8f58cba4ee1fa4c69f5.jpgb80dc0f48d4840a3204ef87faf508679.jpg88eaf1c977c18b11356882b825fc10c0.jpg
I chose 9” because I didn’t need any wider to fit 305s or if I decide to go up to 35x12.5 they’re still big enough.
I was trying to find the balance between wider tires/wheels and not having the tires/wheels protruding from the side of the truck.  Just want a cleaner look.
Thanks.  Seems like 10 may be overkill.  Lots of variations i see between folks rubbing or not.  Most of the rub seems to be on the mudflaps which would seem to be an outside rear tire edge rub.  This would lend itself to a tire that sticks out to far.  Gothp28 showed a -25 offset and bad rub. Most folks seems to be doing better here with almost no offset on 9" wheels. The folks with +1 seem to be okay.  But I know there are a lot more variables to consider
Oh yeah.
My baby has new feet and shoes.
Nitto Terra Grappler G2; 285/55R22
34" rolling size. Perfect fit on this lifted truck.
Slight rub on full lock. ab9e91ababb3a19cf78b62a5df8702d2.jpgd053ffe42fdb61dc4e9608fa7893f31c.jpg
  • Like 4
2 hours ago, Smoothbassman said:
Oh yeah.
Great tire and size, I’m very happy that I went with that same tire on mine as well.
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 457 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
