18 hours ago, Gamecock12 said:
No.. The trimming needed to be done due to the spacers.
Gotcha, Thanks.
On ‎4‎/‎11‎/‎2020 at 7:17 PM, u1bud said:
24x10 gmc reps 305/35/24 rear lowering shackles
Nice truck.  Did you have to use any wheel spacers?  I've been looking at those same wheels in gloss black.  Everyone has told me they won't fit due to the larger brake calipers on the 2019 and up trucks.  Where did you purchase the wheels from?  Thanks.
20 hours ago, hotrodz37 said:
Anybody put bronze wheels on a satin steel truck yet?
Here is mine in carbon black metallic. I know its not the same color, but maybe it gives you an idea?
  • Like 5
Does anyone know the factory 20" wheel offset?
Should be +24mm if I’m not mistaken.
16 hours ago, justin saleeby said:
fuel maverick 20x9  1 offset
285/60 Toyo At3
Nice.  Any lift or level?  Any trimming?
285/60 Toyo At3
Looks good! How do you like the AT3s
Im about .75" front and 1.25" back over stock at4 height no trimming or rubbing
I really like them on the highway, extremely quite. Haven't been to the high country  so not sure about off road capability but they look aggressive enough to handle most anything.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
