Thank you!  I’m not for certain I just had them match the factory rear tint.
2 minutes ago, romclean1 said:
great lookin truck !  what level tint are the front windows ?
I’m not for certain I just had them match the rear tint.
Figured I'd post on here as well.
- Ready Lift 2" SST Lift
- Stock 18"s rims
- Toyo Open County R/T 35x12.5R18
- Supreme 2" spacers (You can get away with 1" if you want. The reason I got spacers was to clear the aftermarket upper control arm)
- Mud Flap Trim delete kit
- Removed the metal bracket behind the front wheels
- Trimmed the liner behind the front wheels so it doesn't rub anymore
Edited by PureZ71
  • Like 4
On 11/18/2020 at 8:21 PM, MBPhotos said:
Ready Lift 2" SST
17x9 Fuel Zephyr wheels
AMP Terrain Pro A/T 315/70/17
What’s the offset on these wheels? Any issues with rubbing?
Hi All
I have went through the wheel and tire thread and cant seem to find the answer im looking for. I have a standard 2020 RST 4x4 with 20in rims and want to get the Fuel vapor wheels and want to know what offset to get and what the largest tire size i can get with that offset without cutting or lifting the truck. IE can i get a -18 offset and run 275/65/20s or do i need to go with +20mm offset and get the 275/60/20s or will the 65s fit on the +20mm offset with no rubbing? Thanks for the help
Not sure if this belongs here but these are just the factory 22’s that come with the Denali ultimate package. I had them chromed for a OEM plus look.
  • Like 5
21 hours ago, puppykat33 said:
Hi All
Traditionally lower offsets would help reduce rubbing however with the style of our fenders it's the opposite. With that said you'll rub less if any with the +20 than you would with the -18. If you like PM me and I'll offer you more specifics and can help you achieve what you're looking for.
On 1/17/2021 at 2:47 PM, Rtalliston said:
Fuel Rebel 20x9+1, 275/65r20, billstein 5100s @ 2" and 1" block in rear...slight rub on mud flaps
Looks good. I’m thinking about something similar. Do you have any pictures in the daytime?
- Stock 18"s rims
First off, truck looks fantastic, bravo very clean yet OEM+ look.
When you mentioned mud flap kit, did you purchase a separate kit to replace where the oem flap is? If so can you link that for me?
On 3/7/2021 at 12:15 PM, puppykat33 said:
Hi All
275 is prolly the largest I would go. also a + Offset is your only real option sadly. I run 20x9 33x12.5 on a +1 offset. That is with a front level kit. Even so, I have SLIGHT rub on full lock.
Of course. I only used the front part of this kit.
https://switchsuspension.com/chevrolet-silverado-1500-2019-2021-front-rear-mud-flap-delete-kit/
My favorite, thanks for sharing. I love OEM and I just ordered this truck in the same color.  Love the chore rims
I appreciate the compliment brother. Post of pic of that beast when you take delivery!
Pro Comp 6 inch lift
20x10 Fuel Rebels in matte black
35x12.5 Nitto Ridge Grapplers
Fabtech upper control arms
I absolutely love it. She drives better than I expected.
Edited by Therickyp
  • Like 5
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
