20 hours ago, MgoBlue said:
Is that stock or leveled or lifted on your set ip
Hey, its leveled. I have the ready lift 2' sst lift kit on the front only. Got it mainly to just level out the truck
Edited by PureZ71
Thanks, ordered a set of the Fuel D750s (same style all black) for my 35X12.5 bfg ko2s. Will be selling my stock wheels wth the black lug nuts and center caps.
On 7/15/2019 at 2:09 AM, GJM32387 said:
Fuel Rebel 20x10 -18 Offset
No spacers
Nitto Ridge Grappler 295/55/20
Factory Trailboss Suspension
Slight Rub on mudflap on full lock.
Truck looks great!  Are you sure that's factory suspension?  Looks perfectly level.  Did you drop the back?
Hello All from Chile.
Here is my setup for 2021 Silverado Trail Boss LT:
- 35x12,5R18 Maxxis Razr MT on stock wheel.
- 2" Wheel spacers.
- 2" Body Armor leveling kit.
- Fox IFP 2" Shocks.
- Camburg Upper Control Arms.
- Trimmed mud flaps (Needs more trimming, still rubbing in full turn and flexing).
On 7/13/2021 at 5:45 PM, Chad Nelson said:
Such a horrible thing to do to a truck
In your opinion! Who cares...it's his money and can do what he wants. I grew up in Norcal and we lowered and lifted trucks all the time. To each their own, stop hating.
  • Like 6
On 6/20/2021 at 2:53 PM, PureZ71 said:
Replaced my stock 18's with 2' spacers for a set of Fuel Block D751 (18X9, -12 offset). I believe this offset is just the perfect amount for these trucks.
http://www.fueloffroad.com/wheel/14570/fuel-1-piece-wheels-block-d751/?finishID=4434&lugs=6
Any rubbing with the -12 offset?  I'm thinking about some Fuels in 17x9 with the -12 offset for my 21 Silverado 1500 and wanted to make sure they would clear the calipers and no rub
Yes, that’s his opinion, and he has every right to state his opinion no matter how much you may disagree or not like it.
Not exactly sure because I had removed my mud flaps and the bracket behind them  before due to my previous setup (Stock wheels + 2" spacers). They will for sure clear the calipers. But -12 is just the perfect amount IMO.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
