10 minutes ago, jl449 said:
Looks good!  What film did you use?  Did you remove the lens?  Going to do this mod on my white GMC 2500
Did not remove the light just used a small plastic scraper and electronics heat gun. Be careful with the heat, the tint will blister if you get carried away.
VViViD Air-Tint Dark Black Headlight Taillight Tint Air-Release Vinyl Wrap Film 17.75 Inches x 60 Inches Roll https://www.amazon.com/dp/B01GQRQ996/ref=cm_sw_r_cp_apa_i_znsDDbH10HMT2
Haven't touched mine as of yet, hasn't really bothered me much.  I do like it at night because going down the road or backing up it gives you a great indicator of where your truck is.
On 9/19/2019 at 8:56 AM, cdh7917 said:
Did mine as well when I swapped on the painted flares.  Looks so much better.
Very nice! Also: Where did you get painted flares?  We just got our Pacific Blue 2500HD AT4. I like this tint mod.
Thank you!
I ordered them through a local Chevrolet dealer.  They're a GMC part that you can find on accessories.gmc.com.
But...they currently don't offer every color, and I can't recall if the Pacific Blue is available or not.  They do offer a primer version, but then you'd have to get them painted.  Not that doing so would be hard, but it would be an added expense.
I have to assume that each color will be offered, at least the colors that are also available in the Denali trim.  But that's just my guess.
Tinted mine last week when I installed the 295/65-20's.
Vivid tint, easy application, just follow directions.
  • 8 months later...
On 9/24/2019 at 8:20 AM, powerhaulic said:
much better i think
Off topic here but are you lifted with the 295/65/20’s? And if not.... do you have any rubbing?
Edited by Doubleu
What I have found about the roof marker lights, is that they aren't normally on the trucks with California emissions. I don't quite get the relation, but a quick search of trucks on lots on Cali vs other states pretty much proves it. Can a buyer order a GMC with the California emissions, but it's actually going to a dealer in another state?
Not sure if these are painted or if they sell a piece you can put in place of the light if you don't like it.67cff7d3311983bb73754107ea53d2f7.jpg
Sent from my SM-G988U1 using Tapatalk
  • 3 months later...
How has the tint held up for you all?  Just finding this and thinking about it, and curious on the long term since most of you have had it done for a year or so now.
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
