Brake / Turn Signal Light Failure
rkiethbennett
2016 Denali 3500 crew cab. Passenger side brake light / turn signal lamp is not working.  Running light is working.  New bulbs.  Is there a fuse or relay that can be checked?  I have not been able to locate one.
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
