1 minute ago, Davidj98 said:
To be safe I disconnected battery during install, not sure it was needed though
I just did the mod this weekend. I opted to not disconnect the battery, had no issues (thankfully). . I had a couple friends to help; we took our time, and it was a fairly simple job.
The hardest part in our case was popping the two clips that hold the headliner up by the rear window. I think they broke when we pulled it down, so I think I'm going to be ordering some new ones.  I think the metal component of the clip is busted (see pic). Not sure how I could have pulled it down any different.
In any case, everything else was super simple, I'm pleased. So grateful for everyone who posted info and pics.
Great job man, those two clips separated from headliner when I pulled, I just applied a light coat of gorilla glue on reinstall.
I am looking at doing something slightly different with this setup, and I have a few questions. Does anyone have an idea of how long the coax cable is ( 84335461) ? And also, from what I can tell the camera looks like it can be removed from the brake light housing. Can anyone confirm? I am looking to move the factory camera and install it on the back of a cap. I purchased the short harness that goes through the spoiler last week from the dealer, as that is the only one we could find on their system. I think with the coax cable, I could just plug it into the existing one which I think would make it long enough to run to the back of the cap and just plug the camera into that.
There are two screws to pull the camera out of the brake light housing, though I admit I didn't try it.  The cable is about 7' in length (at least mine was).
Great! Thanks! I am going to give that a try. The box is 6’9”, and the cable between that one and the camera is about 2’, so hopefully about 9’ of cable total. I will just have to try to figure out a way to mount the camera on the cap.
I'm looking to do this as well. Please keep me/us posted
How does the camera do at night? I hope it's better than the backup camera, because it is really dark. For those of you who have had this for a while, is there any need to use the mirror function over the camera or do you always just use the camera?
So in my opinion, I find it much more useful at night than the mirror.  I am able to makeup a lot more of what's behind me other than just headlights.  However, it is winter here, so 70% of what I see is white :)  However, day or night, I rarely use the mirror anymore.  Here are some more thoughts:
Colors are more washed out than the mirror.  It's a high res screen, but clarity and color can't compare with the mirror. I was also tempted to zoom in all the way in order for objects to appear the same distance in either mode. This probably makes things even less clear because I suspect it's a software zoom, not optical.
Took my brain a while to context switch between the road (glass) and the screen. I didn't expect this, but I'm finding it's going away over time.  It's odd because I don't have that issue with the infotainment screen, but for some reason, the first time I used it, it took a couple seconds each time i'd look at it, for my brain to focus on it.
Perspective. Much improved. I can watch a car in the rear mirror and as soon as it leaves the focus of the mirror, it's starting to show up in my side mirrors, or at least my mirror light shows something is there for the brief moment.  There was a much bigger gap before.
Headlights at night, even though it was auto-dim, don't have nearly the washout effect when using the screen.
The obvious, way more usable data because you aren't blocked by seats, window, etc. Overall, the good far outweighs the bad for me. I love it. i hope this helps.
thanks, yes this helps. Does rain and dirt distort the image like on the rear view camera? I figured there would be times when rain or dirt gets on the lens but probably not as bad as the tailgate camera due to how close that is to the road.
Don't know, haven't had it long enough, and it's winter here. I suspect not, because of where it is, that part of the truck is far less prone to dirt compared to the tailgate.
It is amazing, day or night. Not even a comparison between that camera and the tailgate camera. Mine, which is a 2020 seems to be 4K resolution. When I bought my truck, I thought it was a totally useless option. The first few days, I didn’t like it. However after having it for a while, I really like it. Now that I have a cap on the truck, I really miss it. I have had caps on my trucks for the last 20 years, so I am used to not using the rear view, but I do miss it now. Especially since I use it for snowplowing.
I only used it for about 2 months before I put the cap on, but it never got dirty or distorted like the tailgate one, even in snow.
Have you got around to moving the camera to the back of the camper top?
Did you ever get your camera moved?
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
