Radio works but no sound
I have a 2004 Silverado 4x4 with the Bose system. I just put a brand new aftermarket head unit in it and still no sound so I bought a used amp off eBay, installed it and still nothing.   Fuses are all good and all connections are as they should be   I’ve read a lot saying it could be the speakers. If one speaker blows could it shut down the whole system?   I’m at a lose and nothing I have read has been specific enough to my problem nor has anything given me a confirmed fix   Any help would be much appreciated. Thank you
You'll need an interface unit to connect to a bose system and retain all of your accessories. Look at crutchfield.
You can verify head unit by bypassing the wiring and connect direct to a speaker.
Do I need an interface unit Even tho I’m not using any aftermarket subs or speakers
Yes.
The interface will adjust output to match the ohm rating of the bose amp, interface with RAP and accept system/data for things like door, light, key chimes.
