Talk about taking advantage of a bad situation!
And turning it into a good one!
https://motorsportstribune.com/wallace-to-mcdowell-what-a-joke-he-is/
But wait....There's more!
https://www.ebay.com/itm/Front-Bumper-from-Bubba-Wallace-43-NASCAR-All-Star-Open-Race-in-Bristol/193579959996?hash=item2d1243c6bc:g:zB0AAOSw~51fEd54
Every action has an equal and opposite reaction.  Glad it's benefitting MRO!
How about that!  Klyde Butch gets his Xfin win taken away because he ran too low on the left rear.  Just like his bud Hambin a year or so ago.  Maybe Gibby bunch has a learning disability?
I think NASCAR needs to loosen up a little. They need to go back to when they were really popular examine what made them that way. More money is being spent to keep the cars in tolerance during the race for fear of being disqualified. I use to be die hard never miss NASCAR watcher. Now it’s something different to watch on a Sunday. Tony Stewart supposedly is coming out with a new racing deal next year. Can’t wait for that.
nascar can't loosen up on the rules, as an unenforced rule is not a rule that will be followed, and it will only take a race or two before everyone to modify their cars to not follow it, at the very least just to keep up with everyone else breaking the rule to get an advantage.
I'd like to see them drop the number of cars down to 30. I'm tired of seeing cars running just to collect a paycheck. Only 81 laps into today's race and there's 6 cars more than 3 laps down because of their pace. Just park the car already.
Thinking they are just pacing themselves. it is pretty hot in Texas today, good time to stay hydrated, maybe pull over for a bathroom break, get a fresh soda.....
Can’t learn unless you’re there. The only person I can recall exploded to his potential was BIg E. Probably the best in the last few years didn’t make it in the five car to excel in the 18. Slice bread is another to fail at Hendricks to succeed in the 22. Now if there’s no doubt someone can’t drive at that level. The sponsor would probably be the first to make the move.
After long and careful reflection and consideration, I have decided to bestow the new nickname to one Darryl Wallace, Jr.
May he be henceforth known as....
         "Backfire" Bubba Wallace.
This shall be known throughout the land.
Sponsorships, bump and runs, reprisal trash dumps; nothing is going as planned.
Oh, well.
tumblr_pe2ew1nW5q1qisuk1o2_500.gifv
Doesn't really matter to me. Although I do enjoy listening to Clint Bowyer when he does the Xfinity races. When he retires they need to make him a full time commentator.
Anyone got a preference for which network coverage they like better?
NBC. Better commentary and they don't immediately cut to re-airing the race.
Sent from my moto g(7) play using Tapatalk
    • Its coolant disguised as oil.   TSB - 20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
