And I called (801) 476-3343
Either way I think they all lead to powerteq and give you an option to select a company (I chose edge).
I asked who makes the pulsar and didn’t get an answer idk
I emailed them yesterday and got a email and call from them today. They gave me a different number to call them on, the guy was outstanding to talk to and work with. They said Holley will be sending me a RMA on Monday, I appreciated they didn't try to talk me into swapping for another. I am spooked :) and can't afford to have problems with my truck.
Maybe later when things settle down some
Tom
On 11/18/2020 at 1:43 PM, SILVER SLED said:
I got mine from Diablo.  No difference I'm sure.  Worked great.  Only odd thing is I can't shut off start/stop with dash switch when unit is hooked up and set to not disable it. I can disable it through the unit as designed though.
Mine does the samething maybe a update will fix it? Only other thing I don’t like is the the throttle sensitivity settings them seem to make my truck shift funny kinda like a slip on shift out in like 7-10 gears when just cruising around? Anyone else notice this? 2020 trail boss custom 6.2 (also my truck seems to be ok with changing sensitivity on the fly as long as you let off on the throttle)
Edited by bjr2020 6.2
Mine does the samething maybe a update will fix it? Only other thing I don’t like is the the throttle sensitivity settings them seem to make my truck shift funny kinda like a skip in like 7-10 gears when just cruising around? Anyone else notice this? 2020 trail boss custom 6.2 (also my truck seems to be ok with changing sensitivity on the fly as long as you let off on the throttle)
Mine drove fine, no gear skip issues.
Also, this device can disable auto start/stop, why would you not want to use that feature?
Also, you bought this to disable auto start/stop, why would you want to enable it?
Sorry didn’t proof read lol meant kinda like a slip on shift out of them gears if you watch the tach you can see it and hear it in the exhaust note. Mine has a muffler delete. I meant also with the pulsar say auto start stop is left on you loose the option to turn it off with the switch. If I set the pulsar to turn it off the light goes out and I get a message on start up it’s disabled. I just leave it off on the pulsar as I don’t like the feature anyway. I was just acknowledging mine as same problem when pulsar is plugged in.
I haven't had a gear skip issue but I feel like I do get over revs occasionally. Still trying to diagnose this one, feels like it is hunting at times but overall very happy with the Pulsar. I called Range last week to figure out why my USB to ODBII cable wasn't working and was advised that it only works with the Holley cable, part #98105. If you talk to them and give them your serial number they can tell you if there is an update for your module.
I called Diablo and they said the stop/start can not be turned off with the device installed.  I only changed the throttle sensitivity once and didn’t like it so I went back to stock.  The truck is plenty responsive stock.
Isn’t that nice lol I ordered a cable but it’s not a Holley cable. Also I didn’t mean skip I meant slip. You can hear it in the exhaust note the shift in like 7-10 isn’t as quick as it is with stock sensitivity settings. Seems to have alil torque converter slip in upper gears on shift out is what I mean. But all and all I’m happy with the pulsar.
I like the feel better on like 30% sensitivity but don’t like the upper shifts. Also I agree the 6.2 has better stock throttle response then the 5.3 anyway so it’s tolerable stock.
I don’t mind the engine shutting off at times to save gas.  Like sitting at a long light.  So what I do now when I want start/stop off, I put it in tow haul mode, that inhibits start/stop.
What do you mean by over rev’s? Could be what I’m talking about that’s my issue as well.
Hard to explain it but let's say you driving at a constant speed and you see and hear the rpms go up maybe 500 but I don't feel a difference in acceleration. My truck is new to me and only has 2k miles so this may just be a quirk especially after the dfm disable. I really need to log more miles. I also discovered today that my truck has a Pedal Commander. I may take this out of the equation to see how the truck behaves.
Yea I think it’s the throttle sensitivity or pedal commander in your case causing the issue. Mine when I play with the sensitivity it has flare ups shifting like your speaking of. When I run stock sensitivity it goes back to normal. Keep me posted plz on how you make out. Hopefully maybe the pulsar will have a update to fix the issues. Even though sounds like some work ok. Mines a 6.2 10 speed so maybe that’s the issue.
Just so everyone realizes..... All the throttle sensitivity adjustment does is change the curve on how much the throttle body is open vs pedal input.  It makes it "feel" more responsive at part throttle but it is much harder to modulate the power.  If you have the sensitivity turned up you will notice a nice surge of power at part throttle but it will feel flat when you step into it more because the throttle body is already open more than it normally would be.  I prefer to leave mine at the stock setting and control it with my foot.
-Eli
-Eli
Yup I’m def into what your saying your 100% right. It will give you a dead peddle almost farther in the throttle. Your right 6.2 feels fine stock but if you turn up the sensitivity check out like your 7-10 shift out watch your tach and listen see if it causes what seems to be alittle slip almost like 100-200rpm. I have a muffler delete on mine and you can feel and hear something is just alil off. Thinking maybe the tranny doesn’t agree with the sensitivity change or settings. Would like other input if other ppl notice this? Maybe I’m just to picky? Lol maybe a update will fix it hard saying.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
