Is it still possible to replace just the blade in the windshield wipers? Or is it better to just replace the whole thing?
I would suggest swapping the set to a new blade.  I prefer the Bosch brand of wipers.  Their premium line is the best I've used and last a long time before needing to be replaced.
I'm not sure if you can just replace the blade though.
For the longest time, I have always replaced just the rubber insert. But over the past few years, the rubber inserts are getting harder to find. And now there are multiple widths. Costs a little more, but much easier to just replace the entire blade assembly.
You can certainly get the inserts out.  I haven't been able to find anything to put back in.
Although I haven't been looking too hard.
I've been using these.  I'm happy with them and even with shipping, about half price through RA than at the store.
https://www.rockauto.com/en/moreinfo.php?pk=11105973&cc=3443204&jsn=2535
I'm sold on OEM Direct Fit Replacement myself. Keep the windshield clean and don't run them when frozen to the windshield and they last for years. Makes that $20 price seem a bargain. Wife and I have 270,000 miles between us with once change of blades each. I just put the third on the passenger side of hers. Started them frozen and RIP...
GM has three tiers
OEM Direct Fit ... ACEDelco Advantage ... Professional
GM has three tiers
For some reason I’m not finding anything on OEM Direct Fit, any chance you have a link?
Agree with GB, the factory blades are awesome when new, and do last quite a while.
Found this part number, not sure which level (did not know there were) it is: Blade (Replaced Part Number 23387857) - GM (84578275)
That's the number listed in the owners manual
Take your VIN to the dealer and ask. It's what I do.
Tell him you want the part the factory used to make the thing.
Not a fan of the OE wipers on the 2019 and up trucks. They downgraded from the nice beam design on the K2s to an old school spring arm with aero pieces tacked on.
Maybe the curvature of the windshield required it, or probably it’s a cost thing. Either way, nobody should pay $20+ a pop for those pieces of crap. I ditched them within a month because they lifted at highway speeds. They are ugly too.
Bosch Envision are the best I've ever used.
I agree with Grumpy here. I have been through many different brands of wiper blades and never found the best wiper blade other then OEM from the dealer and there right about the same price as the brands off the shelf. One thing that bugs me is wiper blades that make that flip flop noise going back and forth  across the windshield.
A good cleaning and a 2X application of Rain-X will stop that. ?
Same here and I easily get a year out of them. Probably because my vehicle is so often garaged.
Edited by Minnvmax
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
