Just drove my 2021 Custom Trail Boss off the lot two days ago and this issue (equalizer reverting back to 0) was the first thing I noticed. I thought I had to save stations in order to save EQ settings, but nope... settings/levels still reverted back to 0.🤔
I will definitely try the reset in about 10 seconds...
I have a Chevy Colorado bought it 2 months ago and I am having the same problem it's actually at the dealer right now for that problem I believe it is a software problem I am curious what  the actual cause for this issue
I did the hard reset in April a week after I bought the truck.
Its now almost October and have not had to touch the settings since.
It works just do it.
Probably a software configuration bug on the firmware they loaded on these radios from the factory. As Nhcampbells noted, the reset fixes the problem. I kind of forgot about the issue since it hasn't come up since I reset my radio.
On 4/30/2021 at 3:15 PM, Nhcampbells said:
So same issue with my 2021 Silverado 2500HD LT
2 weeks old and it would not save the settings, radio wouldn't come on when truck was started.
Did the complete reset this morning.
As for now the settings I set this morning have worked all day and the radio is on when I start the truck.
Go to settings and reset system, I had 2 options ( don't recall what they said) but I reset both.
Had to enter phone info etc and reprogram the favorite stations but it's worth it as long as it is solved.
Will report back if it fails.
Thanks for the info about reset.
On 4/30/2021 at 5:38 PM, Random said:
These are the steps I followed to reset the radio in my truck:
1) Browse the radio menu's to Settings > System > Return to Factory Settings
2) Select Reset Vehicle Settings
3) Wait to reset
4) Select Erase Settings and Personal Data
5) Profit
I reset my radio on 4/16/21 and I haven't had a problem since.
It worked!
  • 4 months later...
I have a 2021 trail boss and having the same issue. I’m not plugging a phone in but I don’t use the radio only Bluetooth. Always on my phone and every time I get in the truck the equalizer is reset to 0s. It has only kept my settings 2-3 times when my truck was off for less than 5 minutes. Other than that it resets every time.
 If anyone has heard of a fix, or has any luck with dealership please post.
I’m almost thinking about adding a powered sub and powered component tweeters to lift the highs and lows when the equalizer is at 0 unless someone knows how to fix the issue.
How do you do the hard reset???
Had to enter phone info etc and reprogram the favorite stations but it's worth it as long as it is solved. Basically cleared all the settings. Settings - system- factory reset
Good luck
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
