4 hours ago, AJMBLAZER said:
It required 2 visits?
I had to go twice because the first visit, the dealer did TSB 21-NA-228 at my direction but the programming for that didn't work in my truck. When I went yesterday, they did 21-NA-056 and the programming for that one did work. If I would have known about 056 the first time, I wouldn't have had to go twice.
3 hours ago, BlaineBug said:
If you have a key I don't believe it matters, the auto stop feature will still shut it down.  If you notice your key is more of a button than anything.  You don't have to hold the key in the start position until it starts, if you just blip it, the starter stays running until it's started anyway.
So with the key, the vehicle will run after you put it in park until you shut it off. If you have the "push to start" button, then from the factory the vehicle will idle after you put it in park for 30 minutes with the keyless fob out of the vehicle and 1 hour with the fob in the vehicle then it shuts off. This programming removes the idle time-out feature the vehicle came with so it only shuts off if the button is pushed....or it runs out of fuel...which ever comes first.
Are you sure that with the physical key it won't time out electronically regardless?
I don't believe so(I could be wrong seeing as I don't have one) but I suppose that is a possibility. I had a buddy that had a 19 custom and his didn't time out after an hour but knowing GM, they could have changed the BCM programming lol
I would be interested to know.
I have some questions.
I had this installed today and maybe I don't understand how to make it work.
My 2500HD has a keyfob.
First try I started the truck sitting in it, got out, pushed the lock on the remote and waited to see how long it would run. It ran about 10 minutes and shut off.
Next I just did the rgular remote start with the keyfob and it still ran 10 minutes and shut off.
Any idea what sequence I need to do to make it run longer?
Thanks fo any help
Thanks fo any help
Start it with the push button and try not locking it.
Thanks fo any help
I don't do anything special to keep it running. Start the truck via the pushbutton, when I get out I lock it with the fob, and it stays running. If I use the remote start, I start it, let it run for a bit, push the pushbutton, and continue on. Not sure what's going on with your truck sir...
Thanks for the suggestion but my goal is to be able to leave it running, get out and lock the door so dog can have AC and not have anyone open the door to take the dog or the truck.
This morning I tried what was suggested by getting in the truck, started with push button then got out locked the door with the remote.
it ran between 10 and 20 minutes then shut down.
I am thinking the update isn’t working properly.
I appreciate the replies
@mrtizzomdid the program also extend remote start?  Right now it is 15 mins and off, 15 mins and off.  After total of 30 mins you have to manually start.  Also, did you go to Wenzel or Graff?
Tried calling the dealership and GM tech support about this, they all said that they have never heard of it.  I keep going round and round with them over this and it's getting old.  I'm about ready to take my truck back or sell it.
It didn't extend the remote start time...just keeps it from turning off automatically after you start it manually. I went to Graff...GM gave them a hard time about getting the programming not only for me but a buddy of mine whos also on the fire dept with me.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
    • I had a boat for many years, never had a problem even with a 2 wheel drive 93 Silvy for 20 years. Good tires, proper use of the gas pedal worked.
    • I read through that and I won't lie, my eyes rolled at some of the quirks about how it can turn off the trailer braking for example but I can see how it could help control or even up the torque applied to the ground with each wheel in a boat ramp scenario. But of course what it can't do is increase the torque to the wheels if the need is there as it ends up being like driving the four wheel drive version of a two wheel drive ( high range that is ). So far the neighbor that ended up with the 3.0 duramax with the max tow package which meant the 3.73 gears and high range only, I think its been doing ok for what he has been towing but doubt he ventures off into the soft stuff with his holiday trailer. He may have towed his dads river boat locally with it ( he always used his 6.6 duramax before ), I'll have to ask him sometime if he got into a lack of power to the wheels situation as after all that engine produces a lot of torque at low speed once the turbo winds out a bit and I think it has the 10 speed and if so they have a pretty good first gear ratio at 4.70 I see which is vastly better than the 3 or four speed overdrive models of years ago.
