I'm on my second GM transmission.  The first one died at 122,000 and the second has died at 225,000. Very little trailering, its been though the gears a few times but it has not been beat on IMO. While driving to DFW today, about 70 miles from home, it started to shudder and jump gears with no warning. I made it to work and then drove about 10 miles to where I am staying and it was very iffy if I would make it.
Not sure what to do at this point.  Does anyone know of a good rebuilder/replacement if DFW/Central Texas area?  I'd like to fix it one last time and be done.  Should have done that last time but GM paid for half of it then.  Need a trans and converter and install.
This one has had a tune on it to help with the converter issues but I guess I was too late to save it.
If you live near the Austin area or go there for work you can check out A+ Transmissions. My 4L60e lasted fantastically behind my 6.0
It is some shops owned by my uncles. They do good work and know GM pretty damn well.
I found a shop in Garland that is going to fix and update all of the weak points.
Price point was very fair. Imo.
im hoping it’s as good as the price. With the extended mileage on this truck, I’d get nothing for trade in so I’ll fix it and keep driving or make as an extra vehicle.  It’s still in great shape as it’s always been a highway vehicle. Waco to DFW, Houston, Austin and San Antonio.
I‘ll share where once I get It back.
thanks for the help
You were able to get  GM to cover half of it the first time at 122K miles?
I was under the impression that the powertrain warranty was only good for 5 years/60K miles.
2007 - 2015 5yr 100k miles powertrain
2016+ 5yr 60k miles powertrain
I was fortunate. It was a goodwill gesture from the dealer to get it covered.
I thought Dexon VI was the ATF to end all ATF's, no transmission should ever fail because GM says DEXRON-VI is far superior.
  • Haha 2
Did you ever flip your trans thermostat after the first trans was put in it?  Its GM's high operating temps that has lead to many of the failures, plus the converter design they chose.  If you rebuild or replace, flip or SureCool mod it.
Its not the fluid that is the problem.  Its the heat and converter design.  6L's can fail on ANY fluid.
Edited by newdude
Quote
No, the fluid is BIG part if the problem.  Good fluid would tolerate the heat.  Dexron is a minimum quality standard and while it plays a role, its also is an incentive for licensed ATF's to meet the minimum standard and no more.  Its designed to last the warranty period, after that, its the owners problem.  GM does not want your transmission to last forever, they want to sell you a new vehicle.
Edited by elcamino
Heat kills ANY fluid.
Note all the parts in the sonnax zip kit I listed.
It is just a piss poor design. As all other consumable good these days it was built with low cost in mind. Straight bull. At one point you could buy directly from sonnax. There were/ are more parts that are to be considered upgrades that correct the bs in these gm trans.
No, heat kills most fluids.  100% Synthetic's can withstand much higher temperatures, 300ºF++. There are very few 100% synthetic ATF's to choose from though.  OEM spec  encourages producers to go no farther than meeting the minimum standard.  Few very oil companies are willing to spend more time and money to create higher levels of protection when all they have to do it meet a minimum standard.  Prime example is all the problems GM is having in recent years with the 8-sp trans and all the different iterations of ATF that they are calling for in service bulletins.  They had to go to Mobil 1 to develop a completely new GTL (group III) ATF because their in-house low bid brand was a problem.  While the engineers set standards, the bean counters seek out the lowest price suppliers and with low prices, often comes lower quality.  Good enough.
So changing the fluid more frequently in a 6L80E will help?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
