My Silverado is having issues with the 4x4. It does Engage but it struggles. When I set the 4h it kinds of drags like something is holding it back and it makes a weird sound coming from the front end. If I set it to 4l it really doesn’t want to move. I have to give it a nice amount of gas for it to go but is feels like something is holding the truck from moving. I’m looking for ideas to pin point the issue. Thank you
hows the oil in the front differential? ujoints in front drive shaft ok? manual shift transfer case or electric? if manual jack up the front end, start it up, put it in 4high, shut it off and shift the transfer case back to 2wd and see if everything turns free. USE JACKSTANDS !!!. if electric you will have to jack the back up too and leave the tc in 4wd but put the trans in neutral. any chance some one has changed a diff or ring and pinion and they are different ratios?
I change the oil in the front differential yesterday. It was milky and gray looking. I did jacked up the truck up this morning and I had set it to 4l and had the wheels spinning and the right front tire struggles to spin. The front wheel more so then the rear. The left wheels spin freely. I have own the truck for the last 2 years and I haven’t had any issues until now. Last time I used 4x4 was about 4 months and it was working fine. U joints look fine. Btw is an 08 Silverado Ltz  vortecmax.
thats probably just normal differential function. with out it running do they have equal resistance? all 4 tires the same size and brand?;
I didn’t try spinning them with the truck off. I can try that on Thursday. The tires are all the same. The front right tire struggling to spin and looking like is getting stuck and then free and stuck again normal? Almost like it has some kind of friction for a short time? And is only happening to the right front wheel.  The both tires on the left side were spinning at a constant speed. I just wanted to clarify.
normal action of the spider gears in the diff. unless it's limited slip, if you try to stop the left the right will go faster in an open diff. they don't usually put limited slip or lockers in the front as it won't steer in the slippery stuff
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
