20 hours ago, Wiggums said:
My mechanic said to use that if I don't refuel in over six months. For now, it's been three months when I refuel so.. no need.
use techron, its has stabilizer built into the stuff
I dont get why someone would pay 60+ grand for the lux truck model and then save 5-10 bucks a fill up to put lesser grade dirtier fuel into their engines which the manufacture clearly doesn't recommend. Have any of you seen a person who has taken the top half of one of these di motors apart because the valve caking is an absolute real issue everyone with one of these engines will face, using cheaper fuel will only make the issue worse.
If your a pump and dumper and trade out like you do socks then it most likely will never be an issue for you, the person who buys it will be a different issue.
  • Thanks 2
I can see with not only gas going up trying to save some money on gas using regular or mid grade. I imagine with the money used trucks are bringing currently if things don’t change soon. If people cringe fueling up it will be traded in.
On 6/12/2022 at 12:25 PM, zelmo said:
Recommended Fuel (6.2L
V8 Engine)
Premium unleaded gasoline
meeting ASTM specification D4814
with a posted octane rating of 93 —
(R+M)/2 — is highly recommended
for best performance and fuel
economy. Unleaded gasoline with
an octane rated as low as 87 can be
used.
Using unleaded gasoline
rated below 93 octane, however, will
lead to reduced acceleration and
fuel economy. If knocking occurs,
use a gasoline rated at 93 octane
as soon as possible, otherwise, the
engine could be damaged.
If heavy
knocking is heard when using
gasoline with a 93 octane rating, the
engine needs service.
Peace offering if I may....
Fine point here worth its distinction. The "knock' the sensor detects and corrects for is what is called incipient detonation. It is NOT audible to the average human ear but it is detectable to the sensor. It can run in this condition forever without damaging a thing. LV3 motors eats it like popcorn.
The detonation referred to in the manual above is AUDIBLE detonation. Not the little click clack of the HPFP but an audible metallic rattle or "PING" that is unmistakable from any other sound the motor may make. You won't need a scanner to know your motor is suffering. That one tears things up fast. It can also be controlled with the loud pedal and gear selection (load) which will be required until you get enough space in that tank for 93 to make a real difference. Octane is a blend-able number. Straight up ratio and proportion.
Arguments in this matter are often the result of confusing one type for the other. This is sometimes augmented by the fact that so many younger people have never experienced true audible detonation as the KIR systems in the cars they learned to drive in worked so well.
Enjoy the ride :driving:
  • Thanks 2
1 hour ago, Gangly said:
If you have no knock running E85, then why don't you run it year round, every tank?  I guess some knock is acceptable, or is it that you don't want to pay so much?  Which is it, because either answer will contradict your opinions on the matter?
No knock on E85 all through the rpm range, some knock on 93 at WOT.  I run 93 when the convenience of range is needed and don't want to be looking around for ethanol pumps when out of town.  WOT knock on 93 is minimal, have recorded it to show you guys but don't know how to post it.  Someday I'll corral one of the kids to get it done.
6.2 DI motors are 11.5:1.
No audible knock in my LV3 with any fuel but incipient is as you describe for the 6.2 to the "T" as read by the scan tool. She is still pulling timing running 93! :nonod: But never on E40 or greater ethanol blends. 😎 But until recently has lived pretty much on 87 for her entire life to date. 155K.
LV1 and LV3 are 11.0 : 1 CR
I didn't do a good job of explaining the differences as you have in these two posts.  There is indeed a difference and these new DI motors are less affected by octane than the older motors.
but don't grab a pitchfork and start talking high and mighty
Sooooo, for us memebers in the 92+ octane club, what should we use now🤔😬😯
I knew what you meant 😉 I'm old...🤣
ever since i got my 2019 6.2 i have been like 70/30 using 91 and sometimes 87 .
I never tow but once a week haul a big load 2k . my truck has never pinged , never had any issues on 87 but i also drive fairly normal. I do sometimes get on and the 6.2 roars .
If your not towing heavy loads, or not up in altitude a lot and not racing light to light . 87 does just fine.
For max performance , yes the higher octane does little better.
Premium was $1 more today. I still choose premium because I bought a damn 6.2L for “the power”.
I also read an article that came out yesterday about the high cases of defaulting auto loans.  So many “fools” over budgeted themselves during the pandemic because they had the government money coming in, interest rates were low, and they WANTED something new.  Not thinking about the consequences of what the future holds.  Well it’s going to get worse before it gets better. I just pray 🙏 we as a society can get through it without more chaos!!
Still using premium. Have considered e85 conversion but I got other stuff to do. $5.30 last time I checked
Edit: 14.5 mpg was my last few fillups. I have a weird feeling something is going on since that is a major drop in the past couple months
Edited by shakenfake
  • Sad 1
We just took a trip in our 2016 Suburban with the 5.3 and I installed the ethanol sensor,  Black Bear Performance tuned it and turned on the E85 table and I imagine tuned that as well, or tweaked it.  I ran E85 the entire trip and put around 1,200 miles on it.  We averaged 17mpg when normally would get 21mpg on 93.  The difference is that E85 where I got it was and is that I know of $3.70 and 93 is $4.90 to $5.60 in places in PA.  Our cost per mile was break even for the most part but I didn't do the math 100%.  I just like the performance of E85 and the smell of the exhaust.  Not to mention the benefits of it burning cleaner.  My UOA's prove that.
As for my 6.2, I use 93 and when I can mix E85 along with it.  I found anything more than a 40/60 mix throws a CEL for running lean code P0171
GM and all the other manufactures should just make every ICE vehicle a flex fuel and let us decide if we want to us it or not.  I know it isn't available everywhere.
If you can't afford the premium gas, you shouldn't be driving a truck with a premium engine.  Sell it and buy a Prius.
  • Thanks 2
I hear you if you said that a year ago. Sure we were warned that the current administration is anti oil. In case you haven’t noticed it’s doubled along with just about everything else. So that statement today doesn’t hold up. I personally use my truck as personal pleasure vehicle and can adjust my usage. When the prices drop on the mighty 6.2 or a 5.0 and maybe a hemi 2 door I may scoop one up. I’m starting to see 10K off plus discounted interest rates already. I’m starting to see some housing slow downs. Struggling to buy premium gas, that’s just the tip of the iceberg.
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
    • That's interesting.   There was a factory wire-hole in the back, top of the rear cab, which had a wire for the third brakelight assembly running through it, as well as several holes (10 of them I believe) for all of the studs coming off of the 3rd brakelight assembly itself.   I sealed all of those holes with RTV/silicone as well.   I found it kind of odd, that none of those holes, were sealed with any kind of sealant by the factory - if there was any there, it wasn't very much.   That said, I've been out in heavy rain and have ran the truck through high-pressure car-washes a few times now and she has been 100% water-tight to this point.   I feel very confident in the repair, we'll see how it holds up.
    • I bought a used 2022 2500hd with 6.6L in February. In March took a 2200 mile trip towing our 6500 lb trailer. Changed the oil day before leaving and when we were arriving at our 1st destination, low oil light came on (roughly 1000 miles) it was 2 qts low. Now it towed like a dream, no issue there, and we did go through the mountains of TN, but still, 2 qts! Luckily I did purchase an extended warranty. Brought it to the dealership in April, oil change and consumption test. Brought it back last week, 1300 miles, no towing, and no oil showing on the dipstick. GM is reccomending a new engine (cheaper than them rebuilding), we'll see if the warranty company comes through.
    • T3's and Ibuprofen. I do have a cryotherapy unit (ice machine) and a lift chair that will allow me to raise my legs above my heart.  There are topicals that I can use once the wound is fully healed.
