Thanks. My truck didn't come with one as the dealer hadn't gotten it yet when I bought it. I like to have it digitally as well.
2 hours ago, mafd2 said:
Can't get the link to work. Tried different ways.
It works. You have to take the brackets and the text in it and replace it with your VIN after the =.
I did that and a few other ways. Says error failed to load PDF document. Tried on 2 different browsers Chrome and Microsoft edge.
Edited by mafd2
8 hours ago, PureZ71 said:
Found this link from GM.com to re-create your trucks (and any other GM) vehicle's window sticker. Just replace the "[COPY YOUR IN HERE]" with your actual vin number.
https://cws.gm.com/vs-cws/vehshop/v2/vehicle/windowsticker?vin=[COPY YOUR VIN HERE]
Enjoy!
Nice thanks for the link it worked for me. I have the window sticker for my 2019 Silverado but the guy who took the window sticker off the 2022 Tahoe ripped it and couldn't see the top of the sticker.
Edited by Silverado4x4
 mafd2 I used Edge and it worked.
Tried Edge again and it worked thanks.  It must not like Chrome.
Edited by mafd2
Post or send me your VIN. I'll try to look it up.
Thats pretty cool to have.  I do still have mine in plastic form the dealer too.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
